After a week back home packing Gladiator boxes (I hadn't realised just how long this takes) it is back to Bangkok and the workbench.
The trip home enabled me to pick up some soft half round wire from a jewellery supply store. I used this for the beading and coal rails. Apologies now to the purists: I decided that half-round would be good enough and couldn't face the task of trying to get it consistently oval shaped.
With some trepidation, I cut off the coal rails from the beading/flare/coal rail etch, and used this as a template to make the new coal rails. The etch was fixed to the glass worktop, lengths of brass strip representing the vertical supports taped over it in the correct places, followed by the backing plates. The vertical supports were left deliberately long. The half round wire was then straightened by fixing a vice to the work room door (I guess the landlord doesn't follow this thread) to clamp one end of the wire, which was then given a good tug. The straightened wire was then soldered with 60:40 solder to the supports and backing plates (and itself at the front). The sellotape was then removed to give a completed set of coal rails.
Then it was on to the beading. I decided that trying to do this in one piece was beyond me, so I first made the front verticals with the bends leading to the top of the sides.
I then filed back the flat beading until it was nearly flush with the main panels. The front beading sections were then added.
This was followed by the horizontal beading, which was added as a single length.
Then the coal rails were attached, first trying the fit and cutting the verticals to length, starting at the front on one side and working back, forming the curves and eventually fixing at the front on the other side. When I saw the following picture, I gout out my measuring stick and checked the location of the LH side backing plate as it seems to be at an angle. Fortunately it appears to be an illusion in the photo.
I think that the exercise has been worth it as the half round sections look much better than the flat etch.
