NHY 581
That lower photo looks the spit of the waiting shelter at Minffordd (FR)…
Nigel
Morning Nigel,
I believe it is the very same, part of Bachmann's ever expanding narrow gauge buildings range.
Rob
Nigel
Rob im going to be annoying here so feel free to ignore me but it is possible to remove the vac pipingHornby's non air braked BR J15 example uses the same footplate casting as their Westo's which includes the air pipe along the side and which is impossible to succesfully remove.
Nope that's the correct direction. I know it looks wrong but there it is. If you think the original intention of the line was to get to halesworth and as the crow flies the mill was a little closer to that end of the line than haughley so it makes sense on a completed system to have the siding orientated to be able to dispatch traffic working towards Halesworth.In addition, pretty certain that the siding to the mill should be facing in the opposite direction.
All you need is a good file with a safe edge, plenty of time and to be completely bonkers.
I think your plan to swap parts around is a better option. But note the cab handrails come in long/short versions and will need matching with the right cab sides
Hi Rob,
I'm visiting my Mum, so to ease the boredom, I have Temploted your track plan to suit your layout size. Most of the turnouts are A5s, but one is A4.75 and is a slight Y, to maintain an almost minium 24" radius.
I have not cleaned up the timbering.
There's definitely a little bit of artistic licence going on in John Watsons plan and probably with good reason behind it.Not facing in the wrong direction but on the wrong side of the track.
Fair enough but please do feel free to tell me to stow the gab if I start to sound like one of those awful know it alls.... I'm only as knowledgeable as the information I've learnt and there is so much more out there to discover...Gosh! Not in anyway annoying.
The other thing to note from the plan is the position of the water tower. If were being completely accurate this should be by the shed. There was a point where the locomotive took water between the station and the mill siding but this was just a pond. Might be a nice feature it include?
A Middy thread to watch - popcorn at the ready.
If it is of any interest at this stage in your planning Rob, this is how John imagined Cratfield might have looked had the line opened to passengers and stopped here, not Laxfield - hence the engine shed from Laxfield.
It was to be his last portrayal of the Middy, this time in S7.
The level crossing / platform fun is again at play, as is the push-back to run-around, albeit in a slightly different format to the Laxfield plan, and a coal yard replaces the mill.
The line back west to Laxfield runs out lower right.
A surveyor has been seen stalking the fields off the baseboard to the left - reckon he’s working on a scheme to extend the siding yet another station further towards Halesworth……
Easy tiger...Could a Cratfield side project appear at a later date I wonder........?
Rob
Easy tiger...
Scratfield might be a squirrel - of the sabre-tooth variety.Easy tiger...
Morning David,When I grew up in the 1950s, I only remember signs being in black and white, liberally splattered with rust.
