I’ve been a bit quiet recently mainly because it has been taking me some time to complete the tiling but both sides of the building are now complete and I have also managed to glaze all of the windows. My next job is to glue and paint some interior partitions and floors just to stop the eye looking straight through the houses, then plant them on Elmham Market.
Whilst waiting for the glue to set on each side I have attempted to solve one of those irritating occasional problems on my D&S bogie coaches. They seem to create shorts on some curves and I think it is the wheels sometimes touching and scraping a bit of paint off the underside of the underframe. Reading another thread on this forum I saw, I think, @simond recommending the use of tissue paper to prevent shorts in another environment. I have tried that here by slipping cut pieces of tissue paper between the wheels and underframes and supergluing them in place. I need to get up to the railway to test whether it has cured the problem.
Anyway, a couple of photos of the current state of the council houses attached.
Nigel
View attachment 212518View attachment 212519
York "4mm" slates/tiles are 4mm across, which of course is a foot(!) - something to consider are their TT:120 versions at 3mm across (9" in 4mm). I chose some in "S" scale for my 7mm signalbox as I thought the 7mm ones overpowering. I would buy a pack in TT:120, initially just to compare. I'd certainly use finer ridge tiles on the bay(?). A very fine build, worth the extra effort, I think.Neatly done, but I can't help but think those tiles are massively overscale - comfortably a foot or more across. The images in you initial post also seems to show an awful lot more courses...
I’ve got a copy of a document that gives the historic slate sizes somewhere, I’ll try to find it, and add it to the resources section, meanwhile modern metric sizes here.
Slate Sizes and Weights - Welsh Slate
The weights shown are exclusive of any packaging, or crating material. The weights for other thicknesses or sizes are available on request from our tewww.welshslate.com
Adam,Neatly done, but I can't help but think those tiles are massively overscale - comfortably a foot or more across. The images in you initial post also seems to show an awful lot more courses...
MRJ 301 has a 4 page article by Steve Hall on the York Modelmaking Tiles and lists a table of sizes, including how the different scale sheets equate to sizes in different scales. He also mentions that they can supply them in bespoke sizes.
Apparently the 4mm tiles are "Duchess" tiles 24"x12" (HxW) and the full range is from Singles at 10"x5" up to Empress at 26"x16". He lists "Doubles" at 12"x6" - whether that is the same as "Double Romans" I couldn't tell you.
EMPRESS | 26 x 16 | VISCOUNTESS | 18 x 9 |
PRINCESS | 24 x 14 | WIDE LADY | 16 x 10 |
DUCHESS | 24 x 12 | BROAD LADY | 16 x 9 |
SMALL DUCHESS | 22 x 12 | LADY | 16 x 8 |
MARCHIONESS | 22 x 11 | WIDE HEADER | 14 x 12 |
BROAD COUNTESS | 20 x 12 | HEADER | 14 x 10 |
COUNTESS | 20 x 10 | SMALL LADY | 14 x 8 |
SMALL COUNTESS | 18 x 10 | NARROW LADY | 14 x 7 |
Is the complete building simply two dwellings?
I'm a little puzzled over these houses. Is the complete building simply two dwellings? If so, they are quite large, effectively double fronted, with lots of rooms. With them being council properties, I'm wondering if there's two dwellings sharing a front door?
Thanks Rob, and I particularly appreciate it coming from you as a skilled practitioner in these matters.Lovely building, Nigel and very nicely finished.
Rob
Very effective. One thing catches my eye though, the building regulations at the time this would have been built required a step of at least 6 inches high above ground level at doorways so the doors need thresholds added or the whole building lifted a little on a plinth, unless you have photos showing differently of course.I have now cut, painted and glued in position a range of internal partitions and floors to prevent the eye being able to see right through the houses. The roof has also benefitted from the application of some weathering to tone it down and I think the structure is now ready for planting on the layout. I might add in some plasticard recessed behind the bottom part of the walls and paint it black, then cut trenches in the scenery to bed it in properly. Some photos attached.
Nigel
View attachment 212801View attachment 212802View attachment 212800
Yes, sorry, I probably didn’t make myself very clear but there will be a black plinth type arrangement and a couple of steps from the doors to the ground. I won’t make those until I plant the building as the ground is uneven so they will need to be fitted to the site. I have just figured I will need to make some drainpipe extensions too…Very effective. One thing catches my eye though, the building regulations at the time this would have been built required a step of at least 6 inches high above ground level at doorways so the doors need thresholds added or the whole building lifted a little on a plinth, unless you have photos showing differently of course.
