James Spooner
Hi DavidHi Nigel
I like Your G5 it ran so quiet and smoothly great work,
Do you have a solution to the buffer locking in your mind?
David.
Many thanks! I must admit I don’t have a completely worked out solution yet but was thinking along the lines of a relatively slender bar or rod being semi permanently fixed into the carriage, with a small loop at the end to slot into the loco draw hook. This might need some experimentation as I can see the swing on the back of the loco creating problems if there isn’t enough latitude in this arrangement. I am very open to suggestions from wiser souls to overcome this difficulty!
Nigel
