P-J.S.
Thank you for sharing those links Graham.
Another set of numpty questions... what I always refer to as the frog is actually technically called the "Common Crossing"? And this is measured as a 1:4, 1:5 etc? Would these always be a 1:5, or 1:4 etc or would they be made up to suite a specific location? Using templot you can set them such as 1:4.75, 1:5.25, but all the Jigs seem to be in whole number ratios?
On the plan I have come up with so far (shared again below with notations on) the "common crossings" are 1:4.75 on turnouts B,C&D, 1:5.75 on A, and E is a 1:4.25, which give a minimum radius of 1400 mm on all bar D &E (which are 1800 mm and 1600 mm respectively). Whilst I understand that these may not be prototypical in branch line or sidings situations, could they have existed in an industrial setting?
