Modifications made to the frames to prevent the leading bogie wheels rubbing and not rotating on tight curves, following a similar alteration to the D1 4-4-0.
Scrap brass etch marked and filed to match the frame outline.
Frames after the halt etch "cut-outs" have been removed.
The brass inserts were then soldered in place on the inside of the frames.
A shot with the bogie in place.
The bogie pivot is a replacement item purchased from MOK.
Ian
