Steve Cook
It was about time Simon, its been in the loft for a while
The aim is pretty much a straight forward build as per the instructions, although I'm going to modify the cab so it looks more like Normandy on the Bluebell Railway - it won't be a scale replica however, given the constraints of the original kit (dome is in the wrong place etc).
I will be tapping you up for some idea of dimensions on the bits that I know are missing (pressure gauge, side tank link pipe), but other bits like tank tops will be easy to work out and make from scratch.
Can you have a look through your instructions to see if there is any mention of boiler fitting though please? I can't see any reference in the notes I have, and I'm not sure what the recommended fixings for the boiler wrapper are (soldering, clamping...). The boiler itself has been dropped off with some G1MRA friends for hydraulic testing, might as well make sure all is well before spending too much time and effort...fingers crossed for a good result
