Captain Kernow's layouts
Captain Kernow
A few more images of 'Callow Lane':
The lineside factory of 'Taffson Evans', located on the other scenic board, which I will hopefully start working on before too long:
The water tower and part of the yard at the Coalpit Heath-end of the layout. Still more scenic work to do here:
Entrance to the yard at the Coalpit Heath-end of the layout. Again, the scenic work isn't finished and the main road surface has yet to be painted and weathered etc.:
Captain Kernow
Found a few more views, some of which date from when I had both boards joined together last year.
Much scenic work still required around the signal box:
Looking through the road overbridge towards the board that has been more scenically developed earlier this year:
NCB locos are 'plated' to run on BR metals from Frog Lane Colliery as far as Callow Lane:
Due to the various low relief buildings that I have deliberately placed along the back edge of the layout, the actual backscene will probably be some photos of distant buildings glued to a sky backscene and the whole lot possibly laminated with a matt finish (if my local copy shop can do this). This is a trial montage, which I was quite pleased with:
cbrailways
CK, I mentioned it before, but the way you have the houses going up and down the hills to the overbridge makes it for me. Just needs some laundry hanging in the back yards now.;)
Captain Kernow
More views of the Class 22 and ballast hoppers:
