Easterner
You mean when I lifted several wagons in the air at Southwold. I thought my ineptitude was the reason you switched to Spratt & Winkles
Well I didn't like to say...….!
The one illustrated is an old Ever Ready pen torch that I'd had for a while, but hadn't converted it to a 'hooked' coupling hook, like a few others I've been using over the years.Where did you purchase the torch from? It looks like the ideal size!
Yes, quite right, you found me out, using my new ballast load to stand in for a spent ballast load, wot I haven't made yet!My recollections of spent ballast is there is more grot and other detritus than stone.
I've now finished Herring numbers 3 and 4 and also the Ling. These are all in P4:
All are unsprung and uncompensated.
As 'Callow Lane' isn't set up at the moment and as I can't visit Re6/6 to pose them on 'Marsh Sidings' either, here they are precariously balanced on 'Bethesda Sidings':
The part-loads visible in one of the above photos hide the fact that there is a quantity of liquid lead in the bottom of the hoppers of each wagon. There really isn't anywhere else on these wagons to put sufficient weight, in order to aid road-holding in P4. Without it, they would just be too lightweight and would probably keep derailing. I wouldn't even run such lightweight wagons in OO, to be honest. The two left hand wagons have removable 'full loads' of Whitecliff Quarry ballast and the two on the right will be similarly fitted in due course. Each wagon now averages 45 grams.
Also posed on 'Bethesda Sidings':
Also converted to P4 recently is this Hornby 'Toad'. Apart from a small amount of plastic that needs to be removed from the brake gear assemblies on each wheel, it was a pretty straightforward conversion, although I've also done this one rigid. A hole was also cut in the floor of the van area and a decent amount of lead glued inside, to bring the weight up to 50 grams. It's still awaiting weathering at the moment:
Since the above photo was taken, the brake van has been re-lettered (using Cambridge Custom Transfers excellent product) to a Lydney van.
Finally, I've recently had four P4 converted diesels back from Tom Foster, who has done an utterly brilliant job weathering them for me. Here they are, again posed precariously on 'Bethesda Sidings':
All the diesels will be used on 'Callow Lane' in due course.
Tim, did you use brass bearings on your toad conversion? I have a couple to do in the round tuit pile.
Hi Phil, yes I did use some. I drilled the bearings out with a 2mm drill first and melted them in, very carefully, as is my wont these days.Tim, did you use brass bearings on your toad conversion? I have a couple to do in the round tuit pile.
