7mm Aneurin Bridge ( St Stephen’s General station )
Compton castle
image.jpg image.jpg image.jpg I've been adding the used sleepers this morning fresh off Phils laser cutter and I think you'll all agree they look great. A few coats of stain later and a waft of black spray then weathering
Cheers Phil of Intentio Designs. He also supplies the normal cut sleepers as well.
Compton castle
It's from a Mitchell kit Mark, built a few years ago. It's a lovely model. It's Rob's loco the guy who had the 47xx with us at last years Newport O gauge show
Compton castle
Just a note to let you all know I'm going to add semi out door extensions either side of the Railway room, they're not that big just enough to take a DMU. I really want to be able to run things back and forth in front of the layout. I've been toying with the idea for a while.
Parcels railcars in the form of GW Flying Bananas and 128's. 121 & 117 passenger DMU's
This adds more operational interest. There will be a bit of wrong line running but that doesn't bother me too much.
I keep going on the easy build web site and Pete has a few on Leamington and they are very good especially with sound on board.
I won't start construction any time soon, maybe in the summer if I can manage it, there's a few more pressing projects to do in the garden first.
Bravo,
There's a distinct lack of 'large' scenery in O gauge, probably due to their size but they certainly add impact. It's a shame the smaller one almost totally obscures the turntable.
Compton castle
Your right, I always knew the turn table would be partially obscured but that's the prototype. To think how long I spent trying to find out what the little signs on the table said!!!
At least I know they are there.
Compton castle
Actually the houses are not as tall as the Large stores, but they will dominate the back drop. Il order some more foam board and knock a few of the tenements up so we can see how they'll look.
This layout is all about the buildings really.
Every time I go in to the railway room the size of it still shock's me
