Here's the backhead after making and adding the regular rod and the the firehole door levers, as well as fitting the gauges.
And in the cab.
I need to do some touching up here and there in the cab. The glazing and reversing mechanism were fitted before the backhead which just wiggled in. I've left off the whistle valve and operating lever top centre on the backhead, as there was no clearance for putting it in with them on.
Here's a front view after adding the Railtec 3D decals for the smokebox number and shed plate. These really are excellent products that I wished I'd discovered years ago. They are so easy to use and far more realistic than etched versions.
The water capacity plate is an etching from Fox Transfers.
That just leaves the works plates which I've ordered from Diane Carney.
Next will be the Fowler 4P backhead and cab interior painting.
Peter
