sjp23480
Its the little things that really make it so realistic - lovely work Larry!One of those little nooks. Rust at the base of the iron railings and around the buffers.
Viewed from the bridge. Some work was done around and on the water tank plus every length of rail was given a new coat of rust...
Funnily enough, the sleeper indentations between the two tracks are already there although you have to look for them. They're from a previous headshunt and roughly follow the line of the grass strip..... When you are laying the scenery at the front you may have a better idea of could fill the space. I would be inclined to make some sleeper indentations as if a loop had been lifted and being taken over by nature with weed patches and young bushes.
Pity as i quite liked it but rule one applies so I'll shut up .To save any confusion, the extra siding that was on the left was removed after a couple of days so I have an unobstructed view of the line to the scenic break (bridge).....
And one of those cases where more is better….I’d prefer a case of Shiraz….
