Morning, Larry.
If you take a close look at the first picture I sent you the other day - you’ll need to scrutinise as they are indeed very small - you’ll see the Peco BH fishplates fitted either side of the trap point and to the far side if the BH point, as alluded to by Rob and Adam.
I recall they were a tight fit and difficult to assemble, however, the task can be made slightly easier by sliding a Stanley blade into the gap and twisting, so that it opens it out a little more. You’ll find it makes fitting a lot easier.
Jonte
Jonte
