Struggling on LOL
Basic firebox shape now complete, totally no idea how I'm going to fill the front shoulders to get the radius, may need to take the front former out and add something to it and then pop it back in, might try a layer of lead but absolutely no idea of it's melting point or if it can even be soldered to brass, maybe low melt solder will adhere? an experiment is called for. Did think about an internal bead of brass rod or wire but the radius varies around the front firebox circumference so it has to be something malleable that can be shaped to the varying radii required.
Over all I'm moderately happy that a; it's square, b; it fits the front of the cab though not yet fitted and c; I managed to form the shell from one piece of brass sheet, wasn't easy mind LOL, there were heavy casualties. You wouldn't think three pieces or brass could take so long to prod into something resembling a firebox...I'm beginning to think I should have tackled a B1 or something first!
Next step will be the shoulder radius and marking up for the washout plugs and mud hole doors and a little internal bracing, though still leaving space for a motor and gearbox. I do confess to having thoughts half way through the construction, when it was a bit wobbly, of bracing it up solid and putting the motor in the tender with a thin cardan shaft drive.
I may still do that as the gap twixt loco and tender is very small and well covered and a drive shaft up close to the fall plate will be suitably hidden.
Whether it looks like a Standard 5 firebox I'll inspect tomorrow and hopefully some daylight photos for a change
