Just a small update (scale 1:1 life keeps getting in the way
Managed to get one water tank (drivers side) just about finished but still need to add the footplate to the base, hopefully with a fair wind will finish the other shortly. I was going to add all the fancy curved and stepped wheel splashers inside the water tank, until working out you'll probably never see them, this lady wears her skirts long, so simply opted for square cut outs internally. I may still add the splasher steel work that faces the ground but the walls won't be seen at all.
Also added the front part of the foot plate to strengthen make sure the tanks soldered up square and then realised that the smoke box protrudes below this, so, two options, cut the existing foot plate to leave two fingers sticking forward. This adds a high risk of damage during construction and opportunities for Captain C'ck up and his merry band to make an entrance with a twisted front end, or, leave as is and cut a corresponding slot in the base of the smoke box to fit over the footplate. NB the front end between the frames (when added) will need cutting back to finish behind the smoke box face which has a slight overhang....forgot to cut that when it was not attached!
Hopefully once the other tank and both footplates are complete I'll get back to the cab structures like finishing the rear bunker and internal splashers, then adding the floor etc.
)Managed to get one water tank (drivers side) just about finished but still need to add the footplate to the base, hopefully with a fair wind will finish the other shortly. I was going to add all the fancy curved and stepped wheel splashers inside the water tank, until working out you'll probably never see them, this lady wears her skirts long, so simply opted for square cut outs internally. I may still add the splasher steel work that faces the ground but the walls won't be seen at all.
