Just thought I’d share another idea I’ve had recently (another example of mind modelling).
In the above photos, you might be able to make out the uncouplers towards the end of each of the three roads. These are the Gaugemaster solenoid variety, the fitting of which I recorded earlier in this thread. They worked but needed some customising to help them lift vertically without swivelling. Another issue was despite altering the positioning of the limiter on the shaft, they either failed to lift the couplers high enough to clear the D loops such that they didn’t uncouple, or when they did, lifted the stock with them. Additionally, I found them uncomfortable to use having to ensure that the loco was moved away as swiftly as possible to reduce the time the solenoid was activated to prevent burn out.
Dissatisfied, I recall I’d decided to bin them and opt for the simpler non electrical Kirby method of uncoupling.
However, after researching the use of ‘power drives’ for servos controlling the bounce on semaphores used previously (Heathcote), I wondered whether this could be successfully applied to uncouplers. Unlike the more complicated drivers required fir the bounce bit of the semaphores, all that would be required fir this purpose would be control of the ‘end’ points (and these drivers are able to move the servo arms to the nth of a degree), to achieve the optimum height for accurate uncoupling.
Having learned of the existence of MERG over the years (always considered electronics well over my head!) I did a bit of digging and discovered that members are offered simple beginners kits known as Pocket Money kits, which more than admirably appear to do the job.
So I got to thinking: if I could fabricate some sort of connection to the lifting shafts of the Gaugemaster uncouplers (the end points of the drivers would obviate the need for the problematic bolt-on shafts) then I could achieve precise lift to release the uncouplers without lifting the stock in the process. Once switched, the servo arm would remain in position until I’d eventually moved the loco forward, in my own time, removing the worry of burning out a noisy, vibrating solenoid in the process.
I’m not certain whether it’s achievable, but I’m going to apply for membership of MERG just to give it a go. The good thing is that the holes are already present in the console for the on/on switches required.
