This weekend I have finally got to the point where I can start painting the brickwork on the main yard building.
I have had to do a few modifications including using a hole saw on the base and in the back wall to improve access for fitting windows and stairways after it is painted.
I also had to finish fitting beams and upper walls into the garage. This area was painted white so I masked the area so I could do the white first.
I should have taken a photos of the white painted area before I masked this up, but I forgot and the next photos is all the White area masked up.
Although it is long and awkward I still used my painting turntable.
I then applied several coats of Hycote red primer.
The turntable made it easer for turning round to do the back of the chimneys etc.
I also finished painting the crane bridge section with primers. I used a dark brown for the top section as this will be a good base for it being even dirtier up in the eaves and around the crane tracks. This also need brickwork detailing etc.
In between the painting, the 3d printer has also been going, producing the last parts for the North Lights. I have been making some campings for the top edge. I have to be honest this has been a nightmare with several aborted prints. These are not 100% but they are close and should be fine when painted.
The picture of the wash and cure shows the second batch being cursed this afternoon.
They are now all fettled and painted and will be fitted tomorrow night.
Also on the printer I have drawn a grate for the apertures I designed in the yard concrete.
I was really pleased when I worked out how to create the fall to the middle. There are only 8mm square and 1mm thick.
They have come out better than I thought they would.
Andy
