Hi JohnHello Martin
I am wondering if you can help with a Bassett-Lowke puzzle which has been intriguing me for some time. It may well be that the answer is well known, and I have just missed the obvious, but here goes -
Here are my B-L 0-6-0 and 0-4-0 tank engines. The 0-6-0 is in my 1934 catalogue, so it was introduced by then. Mine is one of the earlier ones, with the big 5374 number on the side. Later on in the 1930s they were offered in LMS, LNER and SR versions. This one is a bit of an oddball, in that it is clockwork but has the 1 5/8" cast-iron wheels with centre slotted nuts. The 0-4-0 tank does not appear in any of my catalogues, but was apparently issued in the late 1930s and was not reintroduced post-war. Whereas the 0-6-0 was re-issued in BR livery and soldiered on to the end. You can see how Bassett-Lowke cunningly re-used the cab, side tanks and boiler fittings from the 0-6-0 in its junior offspring.
So, the puzzle is this. Both these engines (and the others that I have seen) have this maker's transfer on the bunker -
It just says "British Made" after the B-L name. Whereas Bassett-Lowke engines of the 1930s generally have this -
This one is from a Compound 4-4-0. You will notice that it has the company name and "Made in Northampton". Variations include "Northampton Make".
So from this I conjecture that the 0-6-0 and 0-4-0 tanks were perhaps not made in Northampton, but were outsourced to another maker. If so, then who? The engines are tinprinted and built with tab and slot, so it would have to be a builder conversant with this process. I do hope you can shed some light on this . . .
Various questions which I will try to answer.
Were the 1930s-designed freelance 0-6-0 and 0-4-0 tanks made in Northampton? Yes they were. I don’t have a signed statement from Mr Bassett-Lowke to that effect, you understand. But everything about how these models were made and the use of common parts points to production at Northampton. The ‘maker’s plate’ incorporated in the lithography does say ‘Made in Northampton’ in the BR version of the 0-6-0T.
The 0-4-0 version was only produced for a few years just before WW2. It is in the catalogues from the years it was made. As you say, a clever use of common parts to offer a different model but with (presumably) minimal additional tooling costs. The 0-4-0 is quite scarce nowadays. Possibly because it wasn’t produced for long, possibly because the usual claim of ‘scale model’ was distinctly suspect. An 0-4-0T with inside cylinders and 5’8” diameter wheels — how likely is that? I would think quite a proportion of Bassett-Lowke’s customers would not have wanted one on grounds of implausibility. Mind you, the 0-6-0T clearly did sell well and there weren’t many outside cylinder 0-6-0s with 5’8” wheels either. Probably none, actually. I do have one of the 0-6-0 tanks but not in working condition due to disintegrating wheels. It was clearly a popular and long-lived model in the Bassett-Lowke range, so I have justified it to myself on that basis. It really isn’t realistic — whereas the freelance 0-6-0 goods loco, say, was plausible. Freelance, but believable.
I guess the original wheels on your 5374 disintegrated, as they usually do. Because of a lack of suitable replacements, or because of the difficulty of push-fitting replacements accurately quartered and true running, someone has used the driving wheels from a later 4-6-0 or Pacific to get the loco working again. This will have been the easiest way to accurately fit replacement wheels. Obviously, new axles will have been required. Electric versions of 5374 of course always had cast iron wheels. But a smaller diameter and with the cranks quartered by the earlier system of an external plate covering the wheel boss.
Martin
