Eastsidepilot
Col.
I think it’s an American term.'Consist' sounds better than 'quadruple headed single coach', whether or not it's used in the real railway world maybe the drivers amongst us will tell us @Dan Randall ?.
I suspect most if not all railway modellers understand it. The term is used in DCC instructions quite often.
Yes, it’s definitely used on today’s rail network, though having joined the railway myself in 2002 (post privatisation), I can’t say if it was used in BR days? That said, I would imagine it could have originated when TOPS was introduced, but expect Brian Daniels would know for sure?'Consist' sounds better than 'quadruple headed single coach', whether or not it's used in the real railway world maybe the drivers amongst us will tell us @Dan Randall ?.
I was under the impression that TOPS was originally an American computer program? The term could have been introduced then?Yes, it’s definitely used on today’s rail network, though having joined the railway myself in 2002 (post privatisation), I can’t say if it was used in BR days? That said, I would imagine it could have originated when TOPS was introduced, but expect Brian Daniels would know for sure?
Dan
I’m not so sure TOPS was American. If is recall correctly, Brian Bushell, who worked and volunteered on the Ffestiniog, in his earlier days was a key member of the BR team who wrote the code for TOPS. Happy to be corrected though…I was under the impression that TOPS was originally an American computer program? The term could have been introduced then?
According to Wikipedia TOPS was developed by Southern Pacific Railroad and Stanford University in the USAI’m not so sure TOPS was American. If is recall correctly, Brian Bushell, who worked and volunteered on the Ffestiniog, in his earlier days was a key member of the BR team who wrote the code for TOPS. Happy to be corrected though…
Nigel
Typical train set owner, I'd say - just run what they like, with no regard at all for compatible liveries, Regions or Eras.
Col.
Well the first BR diesels were all blackHave to admit that Class 57 thingy does look rather elegant in lined black!
Makes you wonder how well other diesel classes would carry the same livery.
Heljan 4mm specimen:
Well I can think of LMS 10000 - certainly black when finished by LMS (or was it just into BR ownership?) but later turned green by BR.Well the first BR diesels were all black
