Kevin Johnson
Matt it's nice to see your kit and model building is distracting you from other things in life. Sometimes we need an outlet to help.
It's one of those models - on one hand I don't know why I'm bothering because I don't really need it. On the other - I've started it so I might as well see it through.
Thanks John, appreciate it.I’ll be following the 37 saga with great interest Matt. Best wishes for the getting things sorted.
Without going into too much detail, I'm facing having to look for somewhere new to live and all the complexities (including those linked to seeing my daughter) that go with it.
So true, not so much a "right of passage", as a complete impossibility! Mine ended up in the bin and then I had to graft on replacement window frames from another Bachmann body. An absolute faff that I could have done without. What makes it even more galling is that the Shawplan items come without any form of assembly info or instructions.The window frames are the ubiquitous Shawplan items. Adding these to a Bachmann 37 must be a rite of passage for D&E modellers!
Matt
It's described in MRJ 253 -So true, not so much a "right of passage", as a complete impossibility! Mine ended up in the bin and then I had to graft on replacement window frames from another Bachmann body. An absolute faff that I could have done without. What makes it even more galling is that the Shawplan items come without any form of assembly info or instructions.
David
Just pulled it out for a quick look - yours was a fine article.It's described in MRJ 253 -
That's very kind of you to say, thank you!Just pulled it out for a quick look - yours was a fine article.
It was indeed - have been referring to it a lot!Just pulled it out for a quick look - yours was a fine article.
