In what scale Larry ?Another model that can go to bed ready for the layout next year...
There will be restricted space in front of the box because of its closeness to the platform edge, so the drainpipes are mounted on the end...
According to my computer, this day two years ago (21st Nov) saw me completing the same kit as a LH version ...
Thanks. 7mm scale. I'm back in 0 gauge again.In what scale Larry ?
That signal box is a ripper , great job mate .
I wonder if glueing card similar thickness to the slates on the inside of the roof would combat warping?I hope people will learn from my mistake. It is best to glue the bare wood roof onto the building after it is painted and glazed. This way it will not bow and distort when adding slates.
It might work as a counterbalance. But it is safer to file paint off the surfaces to be glued and attach the two roof panels with PVA while they are perfectly flat.I wonder if glueing card similar thickness to the slates on the inside of the roof would combat warping?
That ECW Bristol looks the business. I've got an inexpensive Corgi Tilling green 'decker to mess around with, which will be good enough as part of the background 'scenery'...Lovely models Larry, I would like one of these in Crosville livery but don't have room.
O-scale (1:43) New resin-cast Buses
www.scalelink.co.uk
Geoff
Lovely work, Larry.Tackling things in between showers, the LMS van was finally weathered and varnished today. Photographed in drab light, which suits this ready-for-the-knackers yard unfitted van...
Hi Larry , the bus is great but please tell me you printed off Llanfair T N . If you hand painted it then i will have to take up tiddlywinks or someting . Oh no , i just noticed Llanfair road down the bottom .Getting there slowly. 1/50th or 7mm transfers would have been useful. From postwar AEC luxury coach to a prewar Leyland as running in the mid 1950's.....
Trying to recreate a secondhand bus with a simple local repaint for stage carriage services. Plonked together for the photo...
