I'd never thought about that benefit of the Frog Juicer, thinking that it was an expensive solution to a problem that doesn't exist, as most point motors incorporate switches that can be used for polarity changing.Simon Dunkley said:Using these, you can operate as per the prototype and run against points, causing a derailment rather than a short. This actually enhances the operating experience.
Ah well, one of the benefits of occasionally being off the wall is that you get to think laterally...Pugsley said:I'd never thought about that benefit of the Frog Juicer, thinking that it was an expensive solution to a problem that doesn't exist, as most point motors incorporate switches that can be used for polarity changing.
Not an insurmountable problem to a man of your resources, ingenuity and nous.I think I might have to incorporate one of those into the new layout, if I can work out a cheaper way of switching the points.
28ten said:Over the holiday I got a chance to use a few controllers namely, the Zimo controller which I really liked, the Lenz which I hated and the NCE which i quite liked.
You and me both - and everyone else, I suspect.Steph Dale said:I was not going to try the Zimo one in case I liked it!
Cynric,28ten said:Yes the lenz was the one with buttons. Zimo don't seem that represented in the uk?
Hmm a bit steep for what I need :scratch:Steph Dale said:Cynric,
DCC supplies seem able to oblige: http://www.dccsupplies.com/shop/index.php?manufacturers_id=20
Prices are eye-wartering though...
Steph
Cynric,28ten said:Hmm a bit steep for what I need :scratch:
Thanks for the vote of confidence, but I think you might have over-estimated me slightlySimon Dunkley said:Not an insurmountable problem to a man of your resources, ingenuity and nous.
Now then, none of this faux humilite, else Steve might have a drink or two and rant at you.Pugsley said:Thanks for the vote of confidence, but I think you might have over-estimated me slightly
Jordan said:Absolutely... after all, working a point with your fingers is the original "digital" control... ;D
/gets coat...
Phill Dyson said:mmm.....having been persuaded to try electrickery for the point operation on Withercombe , I wish I had stuck to 'The Original digital Control' (one finger) ;D or 'Wire in Tube' or rodding ...........we learn by our mistakes :scratch:
Phill :wave:
