Some progress today but I had forgot how much hard work some brass kits are - especially when dealing with armour plate and a perceived lack of thought by the designer for the ease of construction. You would have thought an open wagon would be relatively simple
. It also appears there was a era where there was a '
everything has to be built of brass' fixation.
To continue - a lot of time was spent cleaning up the parts after removing them from the fret and this is the first one of the trio on it's way - at least I thought so
Chassis - I've already had to make adjustments to the brake gear by slicing 3mm from the top support otherwise the brakes do not line up with the wheels. I've also noted the wheels have about 3mm lateral movement but I don't know what for? I'll be disassembling the brake gear to move it inwards after reducing the wheels lateral movement.
Body - a bit of a struggle aligning the sides as each side and end are laminated by folding over. I managed it in the end and the sides and ends were tinned, folded over, secured with bulldog clips and blasted with a blow torch. The aligning of the sides would have been made easier if there were locating tabs with holes in which to insert some rod.... see next photo. The buffer beams ends are a fold up as are the door bumpers on the chassis and both have ended up with rounded corners. The wagon end posts are a similar fold up.
Having reached this stage of the now apparent false start there are a several things I'll be altering for the next pair, and partially rebuilding this one, including the brake gear noted earlier.
- adding solder to the buffer beam outer corners and filing them square.
- make new end posts and door bumpers - again square.
Now's the time to walk away, take stock of this lot and with the aid of Percy and his Verances (good band?) make good kit's shortcomings
And a final controversial observation - rather than fill every conceivable space on an etch with kit parts it would be nice if consideration was given by some some (not all) kit designers to aid alignment when having to laminate parts. But alas economics is the driver.
