Been sitting in a coooool house (1840's with 2' thick solid stone walls built partially into a hillside) doing some more on the Bo-Bo.
As I require functioning headlights I drilled out the cast whitemetal ones with a 3mm drill and inserted some 3mm o/d 2mm i/d copper tube to accommodate 2mm tower LEDs.
Tube soldered into light housing - here ready for trimming.
A washer was used as a cutting guide and the excess cut flush with the washer using a piercing saw.
After trimming I used a countersink to clean the end. The light housing was cut off the tube and the process repeated for the five remaining lights.
I also temporarily fitted the truck mounts to check the ride height and thoughtfully washers are supplied in the kit for this purpose. In the end one was required at the D (driving ) end of the loco.
With roof plonked on -
The destination brackets were also folded up and installed - following the instructions as they are handed. And there is also an error in this photo.
The schoolboy error - the A end cab is sitting on the D end. Although the cabs look identical there is one very subtle difference between the A and D ends........
The destination boards will be resized in due course - so far I have Aylesbury, Baker Street , Chesham, Moorgate St, and Verney Junction. Missing are Harrow, Liverpool St, Rickmansworth, Uxbridge, Watford, Wembley Park and a host of others.
