A few days ago the second injector snapped in two when the bends were put in so that set me to overthinking the problem. With a number of injectors to make it seemed to me that a jig was required to drop the holes consistently in the same place, but to do that I needed a much better answer as to how big these things were, and in particular just how far apart those pesky holes should be.
To do this the GA from Bradley was scanned into QCad and scaled using the wheelbase dimension (the Eastleigh one, not the Wills one). Next a simplified version of the injector seen at Ropley using materials that I had to hand or could reasonably make, was superimposed on the injector shown on the GA. The body required 1.3mm tube that I didn't have, so a length of that was turned in a mini-drill from 1/16" brass tube using a small bastard file to do the cutting. Next I took a length of 3/32" brass tube, inserted some 1/16" tube and soldered it in. This was then drilled out to 1.3mm ready to receive the body tube. The holes needed to be 1.5mm apart about 0.5mm from the end - I'm not capable of working to the 2 decimal places shown! My manual riveter (with drop weight) was used to centre pop the holes in the jig tube at the correct distance and the holes were drilled at the correct distance apart - this took two attempts. A fret saw was used to cut a slot for the end stop that also assists in aligning the tool in my pattern makers' vice.
The tube for the body can then be inserted in the jig, restrained by my other pattern makers' vice, and the holes drilled. Once the body has been trimmed to the correct length the end with the exhaust needs to be opened out to 0.9mm to receive a short length of 0.9mm tube bored out to 0.55mm to take the 24SWG wire. Adjust length of this wire and the rebate until the length exposed suits. The short length is likely to overlap the hole, so once all is soldered together the exhaust hole can be drilled a little deeper again
The bend for the cold water feed is quite close to the injector body, so the wire was bent first and a short length of 0.9mm tube threaded on before it was trimmed to length from a photograph and soldered in. The exhaust pipe required a 0.5mm length of 1.3mm tube that was squashed onto the wire to represent the flange shown on the Ropley photo which differed from the arrangement shown on the GA. The bends (which differ between 700 and T9 classes) could then be applied with no danger of anything snapping. These are the T9 style bends. Extra marks would be given for anyone turning some extra detail into those tiny bodies! Parallax error or a bendy steel rule - I'll let you decide.
In other news the gap at the top of one of the cab sides has been almost invisibly filled in. Also shown is the 'Southern' sunshine branded tender intended for 311. Looks like I do get to redo the handrails on the tender after all, at least one of the toolboxes is loose and the supremely delicate and vulnerable plastic top lamp bracket at the back is missing and needs replacing with something robust (and much more dangerous) in steel. In the foreground is a jumble of injectors, injector related pipework and boiler handrail that makes it look more like it's being scrapped than built!
Next we have a bit of an experiment. Perched a little wonkily on the firebox in front of the cab is my cab front, that has been fitted with brass tube framed windows with glazing of the correct diameter made with a 5mm hole punch. Whilst my execution of the idea leaves something to be desired, there's definitely potential there for a much improved look to the cab, and short of acquiring or making another cab front, there's no going back for my T9!
Lastly crossing my workbench for a bit of TLC is this EM Gauge Wills T9 with a Perseverance chassis from the hand of the late Bob Okesford. The loco is compensated on the Flexichas principle with an RG4 (not seized) driving the fixed rear axle. This arrangement required a backhead of prodigious proportions to conceal the chunky gearbox. The centre of the cast running plate had been removed to accommodate the full length chassis with the result that the ride height is not so very far off. At least thirty years old and close to leading edge when built.
