freelance7
Tom,
They are superb,
Paul
They are superb,
Paul
Castles too.the front and centre drivers are close (P4 rims?) - not much room for brake hangers
Thanks very much! The holes were bored slightly undersize, then machined very closely to width over faces using an indexing attachment and a 1.5mm milling cutter, followed by hand finishing to fit the axles. This might have various flaws from a workshop practise point of view, but it worked far better than the aborted square push broach method I started out with (this wandered off centre based on lack of experience, poor technique and lack of appropriate equipment such as an arbor press). the wheels were all plugged, and I started again...Beautiful work as always! How did you make the square holes, by the way?
They sure are Dave! The front brake hangers are very compact and locate more or less on the bottom edge of the frames. The earlier batches maintained this approach for the remaining pairs, though later batches switched to more normal longer hangers for rear pairs.Very neat indeed, Tom.
Boy, the front and centre drivers are close (P4 rims?) - not much room for brake hangers. How does that work? (BR 9Fs had a similar issue, but on them the hangers were behind the wheels, near the frames, then stepping out in line with the wheel treads below the blocks).
Dave.
Dave.
I'm rather excited to see from the latest MRJ that these will be the focus of a new Wild Swan book - let's hope it's in time for Christmas...Hello again,
here's a short update and snapshot of the L&B Manning Wardle project.
I'm excited too! I'm certain though that it won't be in time for this Christmas...I'm rather excited to see from the latest MRJ that these will be the focus of a new Wild Swan book - let's hope it's in time for Christmas...
