Graeme King
Livery, eventually, will be LNER lined green, although pressure of time and limited current personal stock of lining transfers and other final detailing bits may mean that it wears plain green for a while, unashamedly announcing its status as a"work in progress".
Construction in fuller detail is covered on LNERinfo, "Atlantic's workbench..." but in a nutshell: The chassis is a post 2005 Hornby Gresley Pacific loco-drive type with the original 5 pole motor, but with wheels swapped around on the axles to get the (cosmetic) driving wheels to the front, and a chassis extension to match the original chassis front built on 29 mm forward of the original. The extension is largely plastic, to horrify those who believe that plastic cannot possibly be strong, stable and durable enough, but it carries the added front coupled wheelset's axle in a brass tube as a full width bearing. The majority of the body is the type for a 2000-2005 Hornby China tender-driven A3, with smokebox and running plate ahead of the rear edge of the first set of splashers removed plus the separate top piece of the boiler altered. Added to the front of that is the smokebox plus 29-30mm of boiler barrel, plus running plate to rear of first two sets of splashers from a second Hornby tender-drive Pacific. Most of the front of its original running plate has been cut back to just some discreet residual ledges onto which a new running plate was grafted at the higher level. The cab, let into a V cut into the rear of the original boiler after removal of the A3 cab is from a post 2005 type Hornby A4. Plus a ton of filing, scraping, drilling, sawing, multiple rounds of filling, smoothing and priming along with a raid on the spares boxes for fittings.
In order to agree with what appears to be shown on the drawing, the tender (spares again) may end up being an amalgam of a "Great British Locomotives" magazine Mallard streamlined non-corridor tender top on a Hornby underframe which will need alteration of rear steps (as the UF is from a streamlined corridor tender) plus installation of pick-ups and a new drawbar arrangement in lieu of the DCC/sound-ready wiring "junk" that it unfortuately has.
