Neatly overlooking the body slots for now - and for as long as I can - time to consider the brake arrangements of the "large" cattle wagons which were allocated to diagram W1 and W5. As the GWR continued to build W1/W5 wagons over at least 20 years there is, as may be expected, different styles of brake arrangement and each style existed in several variants. In summary, and based solely upon photographic evidence, the different styles / variants can be described as:-
* long-lever, single double-brake;
* long-lever, single double-brake, BoT 1911 compliant;
* Dean-Churchward, single double brake, lifting link, (DC1 to modellers);
* Dean-Churchward, double-brake, vacuum-fitted (DC2);
* Dean-Churchward, double-brake, cross-corner (DC3).
Given that this summary is based upon photographs then there is a chance that there might be a further variant of the long-lever brake and that is noted in the text below.
Long-lever brakes
The Long-lever brake arrangement was a classic Victorian brake... two brake blocks and a handbrake lever on one side of the wagon. The GWR was perverse as ever and used a brake block which was bolted rigidly to the brake block hanger with the hanger pivoted from a cross-bearer. There was a single V-hanger, between the handbrake lever and the tumbler, with the inner end of the tumbler shaft supported by a round rod which was fixed to the underframe. The description of the brake design as "Long-lever" derives from the wagon wheelbase - the wagon wheelbase of 11'0" meant that the brake push-rods and handbrake lever were longer than used on contemporary open wagons (of 9'0" wheelbase) and that fact dictated a later variant of the Long-lever brake arrangement.
Cheap, cheerful and effective, this brake arrangement is illustrated by wagon no. 38262, built on Old Series Lot 464 to diagram W1. See the previous post for the photograph.
The initial design of Long-lever brake was not compliant with the Board of Trade 1911 regulations regarding the operation of wagon brakes in that the wagon brakes could be applied only from one side of the wagon. Maybe the GWR had exhausted stocks of the necessary components... or maybe the accountants decreed that the cost of compliance needed to be minimised... either way the GWR demonstrated ingenuity and used standard wagon parts when rebuilding the Long-lever wagons to comply with the regulations. The additional V-hanger was offset from the wagon centre-line so that the standard, shorter, push-rod placed the brake block adjacent to the right hand wheel. The extra brake block and handbrake lever are shown in the photo of wagon no. 38901, built on Lot 123 to diagram W1.
Photographer not known, a copy exists in the R Tourret collection.
In the 1930s the GWR rebuilt / converted many cattle wagons for the conveyance of Ale in bottles, barrels and/or casks. Fortunately for us the GWR photographer recorded one of the conversions and the photo shows the "double-brake" side of a BoT compliant Long-lever brake arrangement. Wagon no.38659 was built on Lot 66 to diagram W1.
Photograph by GWR.
Finally, the design of Long-lever brakes originated in the days when the GWR used a rigid mounting of brake blocks to brake hangers. Although not seen in the relatively few photographs of W1 wagons there is a chance that some of the Long-lever wagons might have had the original brake blocks replaced by a more recent type where the brake block is attached to the hangers by a pin rather than a bolt.
Dean-Churchward (DC...) brakes
DC lifting link brake
The initial design of DC brakes provided for a double-brake on one side of the wagon with a handbrake lever on each side of the wagon. The two handbrake levers were mounted on one cross-shaft and hence fell foul of the future BoT regulations in two respects:-
* the BoT required that the brake could be applied from either side of the wagon and that the brake
could be released only from the side where the brake had been applied. The DC design allowed for
the brake to be removed from either side of the wagon.
* the BoT required that the handbrake lever was at the right hand side of the wagon. The DC design
had both handbrake levers at the same end of the wagon because the levers were mounted on the same
shaft.
This design of brake is known to modellers as "DC1" and is illustrated by wagon no. 68409, seen previously. Wagons with DC1 brake can be separated from wagons with later versions of DC brakes by the shape and placing of the lifting link between the tumbler and the (handbrake) cross-shaft. Unusually, the lifting link passes between the axleguard and the outer face of the wheel.
DC with vacuum brake
Whilst the DC lifting link brake was an improvement on the contemporary Long-lever brake the design had a down side in that including a vacuum cylinder for an arrangement without a cross-shaft was not possible. The GWR re-thought the DC lifting link design to include:-
* a second set of brake blocks for the (previously) un-braked side of the wagon;
* a cross-shaft between the two sets of double-brakes;
* modified the handbrake cross-shaft and the method of connecting that shaft to the brake blocks;
* a vacuum cylinder and lever for operating the brake cross-shaft.
A neat solution to the problem of vacuum-fitted stock and used widely for several years. This design, known to modellers as DCII, is illustrated by wagon 13812, built on Lot 396 to diagram W1 and converted to diagram W5. Note that the handbrake cross-shaft is at the far end of the wagon so the handbrake lever is at the left hand end of the wagon (and non-compliant when the BoT regulations came into force).
Photographer unknown, a copy exists in R Carpenter collection.
DC with right-hand handbrake lever
The GWR Dean-Churchward brake found some favour with the Board of Trade although the DCII design
did not comply in respect of the position of the handbrake levers. As a step towards the BoT wishes the GWR modified the DCII arrangement to put a handbrake lever at opposite corners of the wagon and for those handbrake levers to be connected by a rod running the length of the wagon. This revision to the core DC concept is known to modellers as the DCIII (or cross-corner) brake. Note that the DCIII design did not comply with BoT regulations in one respect... the connection between the two handbrake levers enabled the brake to be released from either side of the wagon irrespective of which lever was used to apply the brake.
The DCIII brake arrangement is illustrated by wagon no. 13983, built on Lot 337 to diagram W1 and
converted to diagram W5 circa 1908. See a previous post for the photograph.
regards, Graham
