Richard's American Train Adventures
The 90 deg. crossing at Rochelle shows the (uniquely?) American way of fitting as many sleepers ties under the rails as possible at heavily trafficked zones.
Is this is down to the sheer volume of tonnage over the rails rather than heavier individual axle loadings, or something else?
richard carr
Axle loadings are much higher in the states, up to 36 US tons or 32 UK tons based on the maximum freight car weigth of 286,000 pounds.
RIchard
Both GE and EMD offer 'heavy' locos and CSX, UP are certainly two who have taken up that offer; they're standard locos with extra ballast for traction.
GE's ES44AH comes in at a whopping 432,000lbs weight, just over 196 tons on 6 axles; as Richard notes, a smidge over 32 tons per axle.
richard carr
I'm back in the US again, so Friday afternoon I picked up a car and crawled the 130 miles to Goshen (about 10 miles south of Elkhart) in nearly 4 hours. I saw a few trains on the way and a couple when I finally got there.
So on Saturday morning I set off for Deshler planning to go via Kendallville Butler, Woodburn and Defiance in the hope of seeing something interesting along the way.
The first stop was Kendallville, not surprisingly there was nothing happening on the terminal railroad, but there was a green signal on the mainline and I just had time to grab this
An ACe heading a train of 2 bay hoppers
I moved on to Butler another 25 miles east, the Fort Wayne to Detroit crosses the mainline here.
Another green signal so I stopped amd waited for the train.
Woodburn is about 20 miles south of Butler along an almost dead straight road, by now it was raining hard but at least it was warm.
Woodburn is the end of the Napoleon Defiance and Western Railroad, but nothing was happening that day.
Their new GP15 was parked up waiting for Monday
I went back to US24 and headed north east to Defiance to see what was parked up at the NDW HQ.
I haven't seen this one before , a very bright GP20.
All the other usual locos were there including this one.
I headed east out of town, as I did I heard a train on the CSX mainline and managed to see what looked like a coal train heading east towards Deshler. I was stuck in traffic but though I should catch it up at some point. There is General Motors Powertrain foundry plant on the edge of town. There are a number of siding there and I saw a pair of CSX locos near some autoracks, so I stopped to grab a photo.
Once I had grabbed these photos I continued east, I finally caught sight of the train from Defiance near to Hamler about 6 miles from Deshler so I was hurrying to catch it up.
This was as close as I got, I'm on main street in Deshler, and this is the DPU, you can just make out the train heading towards me in the distance.
It looks like it's a stack train
richard carr
I moved to the west end of main street and checked the signals in the distance,
It's a red over green so something else isn't far behind that coal train
Another stack train heading east as the westbound leaves Deshler behind
Lots of trailers on flat cars so this must be a hot train
There's even a trailer in a well car, I haven't seen that before
So now we know red over green means changing tracks but full speed ahead once you have.
It all went quiet after that, I saw this one parked in the south, but then someone told me it had been there for 2 hours so far.
While I was stood waiting I noticed this very short piece of rail
Everything went quiet, nothing moved for over an hour, then the train in the south finally got moving.
Then the boss rings and Jim arrives, 2 trains go by while I'm on the phone. It's all action again.
At junctions or crossovers they will place two sets of signals, one above the other, in the UK/Europe we’d use one set and a feather.
The higher set is virtually always the main line and straight on, the lower is the diverging route.
This is where the phrase ‘high green’ or ‘high ball’ (back in the day when signals were spheres) comes from, it indicates all clear straight ahead.
In this instance the trailer train has priority over the coal so likely switching over to do a rolling pass.
richard carr
Once I had finished with the Boss, more trains arrived, this one cut across the tracks and turned south.
An ES40 DC
It wasn't jus autoracks but lots of interesting freight cars
Next up was an east bound manifest changing tracks as it entered Deshler
Compete with a heritage liveried DPU
Then a westbound stack train
richard carr
Next came a train from the south, this time with an interesting lashup. the second loco is a an SD60 and the third is a road slug.
The road slug, so no diesel engine, just traction current from another loco. I've no idea if it was actually working
It's the coke express again making it's way back to Pittsburgh
And the last train of the day for us was this CP powered stack train, a bit unusual as the DPU was cut in about 10 cars back from the front, it wasn't a particularly long train which I doubt really needed a DPU at all.
The slug won't be powered, they need specific mother/cow/master engines modified with traction motor power cables; usually other smaller B truck units. The SD60M (in it's self a good catch) does not have that feature so the slug is in transit to somewhere.
richard carr
Sunday morning I set off for Elkhart but realised that I wasn't going to get there before McDonalds stopped serving breakfast.
Satnav said Sturgis was the nearest one so I left the freeway and headed there.
It's a while since I've been to Sturgis, these days this is branch off the Grand Elk leaving at White Pigeon, formerly it was part of the New York Central original route to Toledo. Now the branch ends in Sturgis.
I didn't see any locos parked anywhere but these plastic pellet hoppers were there.
I'm pretty certain they are carrying plastic pellets as the building to the left that you can't see had a big sign saying plastics manufacturer on it when I drove past. The wheel rims are shiny so they haven't been parked there for long.
Here I'm looking towards the end of the line, the route carries on to Coldwater but the track isn't usuable anymore
So then it was on to Elkhart following the railway, there were some box cars at the junction waiting for someone to collect them.
I went to the Amtrak station and in the distance was a head light. It wasn't long before it arrived.
Once that had gone by I went to the west end of the yard, there was nothing doing at all.
I gave it 10 minutes then headed off to Pines Junction about an hour away.
richard carr
If you hop back on the interstate it doesn't take long to get to Pines Junction, although you do have to drive through the worst part of Gary.
The first train to arrive was this manifest on the NS tracks.
In the yard you could see that they were sorting out a Coke Express train getting ready to leave.
Then this train started heading up the hil and over the tracks, a couple of GEs leading but two SD70s following behind
It looked like they were departing but they stayed on the bridge over the tracks for 15 minutes before pushing back into the yard in the end it was over an hour before they left with a fair bit of switching in between.
Next I had a BNSF powered stack train heading towards Elkhart
Then an NS road railer turned up once the the train ha gone by and set off along the track.
I walked over towards the CN tracks, in the distance you could make out these 2 locos an SD38-2 and GP38-2
Then these 2 started taking a train up the hump
But it soon pushed back into the yard and these 2 came out of nowhere
These 2 then started a train up the hill
and at the same time the other train went back up the hill too, hidden behind it.
richard carr
And the last train at Pines for me was this NS stack train.
I decided to head to Dolton Junction after this, it was the first time I had been there for 2 years. It's further than you thing to get there and took about 40 minutes
Not a lot was happening when I did get there and others were looking to leave but I hung around and eventutally a signal turned green and this came round the corner from Blue Island
A very interesting lashup
A CSX SD70 and a CN SD75s and a CN SD70M2
richard carr
After that lashup I didn;t really expect to see anything else interesting, but this was next as this car is clearly driving round the gates and that train is doing about 25 mile per hour.
A pair of SD70s from UP
Then I get blocked again as another CSX train goes past on the far track
Then a UP powered stack train appeared no doubt heading to North Baltimore near Deshler.
There were a couple of trains hiding in the south east corner of the junction but neither moved more than a few yards in the 90 minutes I was there. So no it was time to drive back to O'Hare and go and get pizza for dinner.
UP 7028, you don't see many of those these days, especially on point. One of GE's convertible 4400/6000 HP units (AC4460CW), some were built with 6000 HP engines, the rest with 4400 HP engines until issues with the 6000 were resolved, they never were, but the 6000 soldiered on much longer then EMDs similar units.
These units still have the largest radiator packs of any US engine, wider, deeper and large rear overhang, the newest Tier 4 ET's are close but no large rear overhang; I think only the Australian export version had larger. Note also the raised walkway over the air tanks, another spotting feature.
What units remain are going through a modernization program, usually improved cooling to run the engines hotter for fuel efficiency and cleaner Tier rating and in the case of DC units, conversion to AC drive. The second unit is also a modified, the radiator cores are sat proud of the cabinet.
I was lucky enough to see a full bred CSX AC60CW in Florida, the audio was impressive.
richard carr
I'm back in the US again, so Wednesday evening I decided it was time for a curry in Elmhurst.
Fortunately you can take the train there from the OTC, it's the UP west line to Elburn.
The noise in the station is great, just so loud.
Another train arriving
Thats mine on the right and it's double headed as it's an express so it only calls at Oak Park then Elmhurst
The train was there in about 15 minutes, unfortunately you can't see much of the UP yard as there are buildings between the mainline and the yard. I did see a snoot nose SD40 paired up with a GP15 waiting for their next turn.
Once at Elmhurst I walked up to the second crossing west of the station, the trains come thick and fast this one was just 10 minutes behind us
A few more minutes and the next one arrives
A green signal on the centre road usually implies a freight is on it's way
Here's a Chicago bound train
It's all green heading west
The armed forces tribute lococ
and another double header
and finally that freight turns up, a stack train, that was mainly empties
I now went to get my curry which was excellent as usual.
So about an hour later I'm back at the station and another stack train arrives
That's it for this post I've reaches the 16 photo limit.
