Lawrence Boul
At the time I was hung up on something compact (and this is 16.5mm gauge). I also use servos for uncoupling so it simplified matters to use them for both. DCC - Ex is pretty much plug and play and the Rewanui control needs are relatively simple. No detection, signals, interlocking or anything of that nature.great minds - I have been working on servo drives for turnouts, on and off for some time. Arduinos offer the control, and can easily be interfaced with a CAN bus, which is the architecture I have elected to pursue for everything that is not loco control which remains DCC (I do have a couple of R/C but they are the exception and are not really intended for regular use - more an experiment).
CAN has many advantages, it is very tolerant of electrical noise, and can effectively work "plug and play" - for example, a lever frame can be plugged into the bus outdoors on a nice day, and indoors if the weather is inclement - though I guess you might not want the trains running in the rain. And lights, etc., can all be controlled by similar CAN compliant modules.
I saw an elegant solution for the servo cam drive a week or two back, I think it was one of the guys who are regular contributors to the Templot forum - rather than a cam, it used an eccentric and a small profile rolling element bearing. I didn't see or hear it operating, but it looked to be very well designed, with space to fit up to 4 microswitches I think. It's quite a bit bigger than your design, but that doesn't worry me as I am working in 7mm.
The beauty of a cam or eccentric drive is that the blades are pretty much locked with negligible power demand, backdrive is not possible. I guess that could also be a disadvantage, but generally I think not.
cheers
CAD, 3D printing and cheap Chinese hardware does allow the creation of elegant solutions that in times past would have been impractical at home. Once upon a time you read about something and maybe built it with a few refinements. These days it's far more about gleaning the germ of an idea and building something tailored to need.
If this was a home layout the noise would be an issue for me, and I'd be looking for something silent or at least quiet. At a show audible confirmation is not a bad thing.
