Ressaldar
Hi Mike
Sorry, I was too cryptic. I was just wondering whether that was Tim's coach you were working on? It looks great.
I guessed that you might have been and the answer is yes it is.
cheers
Hi Mike
Hi Mike,at long last, I have started work on the conversion of the 121 Bubble car W55035 into Departmental ADB975659 - based around photos found on Flickr.
http://www.flickr.com/photos/22209362@N03/8387267704/in/pool-881284@N21/
It appears that all of the doors apart from one pair on the non-smoking area were all sealed up and their lower hinges handles etc were removed. The non glazed guards doors were also sealed up and possibly the glazed door as well - the gap at the bottom of those doors was 'boarded over'. I have assumed that all seating apart from the non-smoking area was removed (location of the chip and speaker later on). Initially the partitions remained (as will be modelled) but later photos show all removed - although Bachmann managed to locate both partitions in the wrong places, so they have now been relocated.
The only other body work to do was 1) cut holes for the fuel tank filler points and place the castings obtained from Shawn Kay at Easybuild, the trim around these holes is still to be applied and 2) plate over the route indicator boxes, this being done with some 10 thou brass.
I intend using a Zimo 648 00 Gauge sound chip and 5mm dia red/white combined LEDS for markers (the holes are 4.8mm dia so they will need filing down slightly.
I have already obtained a set of Westdale underfloor castings to supplement those fitted by Bachmann, also the buffer beam detailing and the desk units. The buffers - 3 oval + 1 clipped, have been obtained from Northants Model Railway Supplies, having spoken to Graham Jones at Leigh last week-end, sent him the photo on Tuesday - received the buffers on Thursday.
So hopefully, a busy week ahead and then it's just a question of the H33 Restaurant Coach conversion to run with it!
cheers
,, which unfortunately left some rather large rectangular holes that needed to be 'filled in' as the replacement body baseplates were a lot smaller than the holes that I was left with.
Looking good mate more picture required keep it upThe sun came out briefly and for once I was ready for it
chassis with all the bits, bar the end steps and long lamp irons - I will source some suitable steps at Cleckers and fabricate the irons from etch fret spares.
close up of the exhaust end, you can just make out the holes for them to fit into
t'other end, the jumper terminals are from Westdale, the buffers from Northants Models, cast pipework from Invertrain , air pipe is a Hlejan 'spare' and the couplings are from Premier
elevation showing the Westdale window surrounds + the handrails that Bachmann left off
close up of the exhaust end. The bi-colour LEDs are a nominal 5mm dia and the id of the housing is approx. 4.8mm dia, so hopefully not too much fiddling to do for an interference fit, I also intend filing a flat on the end of the LED to avoid fitting a 'glass lens'.
Internally, the drivers desk and partitions + the seats in the 'non-smoking' compartment are all that remain - this will all be done once the electricery has been sorted, which will probably follow the painting.
More soon
cheers
when it comes to elecktrickery )
Another cracker Mikeit's good to see you back at the soldering too.
Hi Mike, It looks great! Am I correct in assuming it's mine? Cheers Tim
involved here, and a lot of black coffee
