Hi all.
I am building a High Level jinty chassis in P4. I used the "P4" spacers, and the frames came out to 16.2mm outside width. The bearings and hornblocks, however, are a bit wider; 16.55 over the hornblocks and 16.7mm over the fixed axle's bushings. My axles (Gibson P4) are 19.93 mm long give or take .02mm. If I press the wheels on with my GW wheels press until the face of the wheel is flush with the axle center, the back to back is too narrow. Even if I press them so the back to back is right, there is less than .1mm clearance between the back of the wheel hubs and the fixed axle bushings. I can file the bushings back a bit, but 1: How long should the axles supplied with the wheels be, and 2: should pressing them flush with the GW press set the back to backs for me? I am using a 17.75mm B2B gauge from DCC concepts, if that matters.
I suppose I can carefully chuck the wheels in my lathe and skim a bit off the back of the center boss, but - I'd like to avoid that if possible.
Help!
Amanda
