Probably... actually I was commenting on the orientation of the body of the steam heat cock - the pressure relief valve on the prototype is at the bottom, not at the side (um, I did offer this image to you last month... for a small fee I can forget conveniently the gist of your reply... I don't know the provenance of the castings, but the handles are separate parts that fit in holes. I've managed to glue mine in the wrong way.
).the pressure relief valve on the prototype is at the bottom, not at the side
Those Mk2 images are so sad... the rot and grot does not help. Interesting that the steam heat pipe has been blanked.
It must have been a very mucky job being a shunter!
Really looks the part. I look forward to the next installment![]()
The table tops look a little narrow to me, no reflecton on your superb work thoughThose damned tables will be the death of me. Tops come adrift, they don't sit square in the floor slot, the slightest knock - even breathing near them! - dislodges them. I think some Evergreen strip reinforcement will be required to make sure they stay put once sealed inside for all eternity!
The open seconds and brake open seconds perpetuated the interior decor and fittings of the 2As and their successors but in the vestibules of these, and also the firsts and brake firsts, the end walls and door internal skins featured GRP panelling of a bright orange-red hue.
Hi Heather,
If you need more prototype pics of MK2s let me know. I took rather a lot of close-up pics last May when there were about 25 of the things strewn across a bus yard in Yorkshire.
Tom
