tomstaf
Hi Guys,
I'm going to open my workbench with a list of tweaks and improvements to one of my 7mm Heljan 33s. The first will end up at 33 051, Shakespeare Cliff modelled circa 1998 after its 1996 BR Blue repaint at Stewarts Lane. I promise the others will be ending up in Dutch!
My list of planned improvements;
First off is dealing with nne of the most obvious deficiencies: the prominent mould line along the entire length of roof. I simply removed this in a couple of hours with a file and various grades of wet and dry paper.
I then turned to the fan. It's too wide so the aperture needed reducing. I cut a 100mm length of 1.5mm x 4.8mm evergreen styrene strip. I then curled the strip in to a circle and fixed it with a mini clamp. Immerse it in boiling water for a few minutes and then shower it with cold water. Removing the clamp will leave a slightly kinked circle. So cut off the two kinked ends reducing the strip to the circumference to 86mm. I then had a perfect circle that will pressure fit into the roof aperture. Apply some plastic weld and leave for a day to fully harden. After which I filed to match the roof profile. Shawplan's fan replacement etch has two parts. Whilst they were still attached to the etch I lightly tined both parts. I then placed the inner ring on top of the outer. Applied some flux, heat, and let the capillary action draw the solder around the joint. Obviously the mesh needs rolling to match the roof profile too. I was keen not to loose the finely etched mesh detail under paint I dipped the mesh in Birchwood Casey gunmetal blackening solution. I then glued it all on to the roof.
The bogies have the same problem as the 4mm model: the centre bogie springs are incorrectly inline with the bogie frame rather than being recessed. I scored the centre line on the back of the bogie and then cut the springs off. I then used glued a piece of 5mm x 5mm x 25mm plastic angle on to the back of the frame to provide the new surface to glue the springs to. I strengthened this with a piece of 2.5mm x 2.5mm x 25mm square plastic strip and glued the springs back on and resprayed.
The buffer beam detail is uber crude - to me! So JLTRT to the rescue. Some of the pipe work needs to be made from bits of brass rod. The other pipes are just a direct replacement. Thankfully HJ didn't glue them in, so they pop out easily.
More to follow soon.
Tom
PS Sorry for a BR Blue 1st post!
- Remove roof mould lines;
- Replace roof fan with with correct sized Shawplan Extreme Etchings set;
- Realign bogie frame suspension springs;
- Add eyelets to the solebar;
- Reduce fuel tank width;
- Replace buffer beam details with JLTRT parts;
- Add JLTRT high intensity headlights;
- *Add Shawplan cab door kick plates;
- *Replace glazing with Shawplan lazerglaze;
- *Add Shawplan radio rood pod;
- Add Extreme Etchings nameplates, depot plaques, double arrows and shed plates;
- Transfers by Precision transfers;
- Weathering.
Tom
. Keep posting those progress pics
shouldnt be unduly difficult for a man of his talents.
