This week I decided to make the footplate. I noted earlier (above) that the chassis has brass overlays on the outside face. They don't fit very well, and I couldn't decide where to mount them. I decided to use the bottom of the frames where the bogie wheels will sit, and the bottom rear of the chassis. In this position the holes for the brake hangers nearly line up. The overlay overhangs the top of the chassis in various places, so I thought it would be prudent to make the footplate, fit it up and level everything.
The footplate has the valences mounted on a sub frame designed to keep everything flat. It is designed to hold the basic footplate structure square while fitting all the overlays, buffer beams and cab. I couldn't find anything to make the 90 degree fold between the valences and the footplate. I gave up and cut off the sub frame and just bent down the valence gradually with some pliers.
There are a couple of sub-structures to hold the valence at the rear and the front which fitted up quite nicely. All the overlays for the footplate top and the curved bits at the front went on quite easily, as did the splasher tops and the valve chest cover.
I decided to make the cab as a sub assembly to make sure that the curved section of footplate at the rear would match the profile of the cab bottom. It was another rabbit hole I didn't want to go down, but had no choice. The bits of half etch overlays for the rear curvy footplate are a bugger to fit up properly, and are too short by about 0.8 mm (it says so in the 'instructions.') Anyway by this stage I was becoming a bit frustrated by the whole process. The sub structures and fold down allignment parts are, no doubt, designed to help, but were actually becoming a hinderance to the build. Also they're permanent on the footplate structure, and are visible from underneath. They become structures that aren't there on the real loco.
Anyway, moaning aside, it did make quite a pleasing cab and footplate structure.
Climbing back out of successive rabbit holes, I then tried to fit the chassis up to the footplate assembly. It was as if the designer of the footplate had never met the designer of the chassis. Back to the wretched chassis overlays, they needed a fair bit of modification to make the rear and front of the chassis land where I assumed they needed to on the footplate. I had to remove all the outriggers on the chassis and the front chassis stay. The bracket for the fastners had to be cut off the rear of the footplate and repositioned, while the front of the chassis didn't have any provision for screws. Lots of tea and podcasts later it all fitted up.
I then discovered that the footplate on the tender has an extension that raises it up to cab floor level. There's nothing in the kit for this, or if there is the 'instructions' don't mention it. I modified the front of the tender with scratchbuilt parts.
Next up was the cab roof. There's a moulded resin roof in the kit. Mine had curled up along all the straight edges, had a broken rain strip and a finger print in the middle. There are etchings in the kit for a metal roof, which I made up, as I decided it was quicker to fabricate a brass roof rather than mend the snotty resin one.
In the end though it did look well. The chassis was levelled, and the wheels still turned freely.
Back briefly to the valence. The valence folds down from a sub layer of the footplate. The half etched fold lines aren't continuous, and the gaps are a nightmare to fill smoothy when you've fitted the footplate top overlays.
Back next week with more battles.
