Thanks for resurrecting this - it's from a couple of years ago
With reference to what you were responding to
Col,
No doubt someone will correct me if I am wrong but I believe you can usually only laser cut from one side, so if you want your planks marking inside and out you need to use two layers.
It's another project I need to write up and publish. When I got my latest laser cutter I purchased and fitted a cheap laser crosshairs to the laser head. It is now very simple to laser etch plywood from both sides and accurately aligned , no jigs are required and it has totally transformed my laser cutting efforts.
Basically Lightburn software has an x-y offset function. So you etch one side of the wagon, turn the side over, use the crosshairs set to one corner and laser etch the other side, the offset positions the start of the laser cut precisely where the laser crosshairs were so it can laser etch the inside planking as well on the same piece of plywood. Very simple and very quick - I'll try and get a more thorough user guide written up as soon as I have chance.
