Tim, usually Loctite 480 or Devcon 5 Min epoxy, but never flat surface to flat surface as I find they pop off after a while, I always add a secondary fixing, something that protrudes from the brass and fits into a socket in the resin or vice versa. The adhesive bonds better if it can grab two surfaces at different angles, 90° is good.Mick,
What adhesive do you favour for gluing the 3d prints to metal particularly the slidebars to the cylinders?
atb
Tim
The sand boxes are hollow on their back, soldered to the frames is a hoop of 0.6 mm wire that sits inside that hollow, the hollow is filled with Devcon and placed over the hoop and positioned in it's final place, the Devcon gloops down and around the hoop and bonds the two together.
The cylinder blocks have holes in the rear into which two 6BA threaded rods are inserted and secured with Devcon, the thread gives it extra grip; I've tried with smooth rods and if you give it a twist, it'll pull right out. The studs pass through the frames and are held in place with nuts on the inside.
The motion bracket will be soldered to the frames, the slide bars are soldered to the motion bracket, at the front end of the slide bar a tang fits into a slot in the cylinder block. Both parts are respectively secured to the frames so there is no need to bond the two together, their loading is taken up at other points. As a double fixing I may add 480 to the tangs when I finally fix the cylinders in place.
