More JLTRT 4F, I've built three of these 4F's from three different kits, each has their strong points, each their faults, the ideal model would be the best of all three.
All my previous JLTRT builds with resin boilers also had the etch work for the metal one but missing any castings used on the resin moulding, the 4F broke that duck and this is about as far as it goes with the kit metal work once you take the resin boiler out.
The smokebox will be a 3D replacement with door and chimney as one unit for strength, the rest will be scratch built so out with the crayons and scissors tomorrow.
Other than the cab the rest of the etch work was just fine, just over a day (a long day admittedly) to do the rolling chassis, rods and footplate shell, the rest of today was on the cab.
The cab comes in three pieces, why I have no idea but the joint in the roof section isn't anywhere near any guttering (which by the way varies a lot over the class) so you end up with a butt joint and endless filling to smooth off. Luckily the material is quite thick (0.5mm) so there's plenty of meat there so you can attack it with big files.
Not with standing the three pieces the joint is close to the cant rail bend, which makes it awkward to grip/hold the roof section to form the bend. In the end I soldered two slabs of sheet metal on (show as a red overlay in one photo), one covering the opening in the side sheet to stop the small top rear extension distorting and one on the roof section to extend it as a hand hold for bending.
The cab floor also needs some work and the square boxes are a little long and stick out the back so need shortening. The floor has a piece missing where the drivers side box goes, the instructions do note this (thumbs up for noting and advising) so that's easy to add, but, there are no sides where the floor extends past the side sheets, those'll need adding from scrap etch.
Finally you can line the tender up and see that the floor is much too high, which is why I hadn't fitted it previously. This is quite common for tenders that are multi class, the floor section will be for the highest foot plated engine it was attached to, in this case I believe it was the Royal Scot class.
On the chassis I added the obligatory Lego sand boxes, hornguides/springs and ashpan. One thing none of the three kits model is the extended bracket for the leading sand boxes, this pushes the box out and wraps around the leading brake hangers.
