Lancastrian
Mick,
Stunning.
Ian
Stunning.
Ian
It's finally done, not much to show from the previous update , mostly nick nacks and details.
Up next a kit I've already had experience with, a MOK King Arthur though this time with a Maunsel cab. The 4F will trundle along as well and two LNWR tanks will drop in the mix as and when.
Beautiful job Mik, excellent workmanship.Another one bites the dust, excellent work Mick.
Mick,Finally found some time to reassemble the Princess Coronation. It took quite a hefty shunt and more than the cab took a hit, most has been straightened as best possible but to make it factory fresh would have been prohibitively costly.
I've shown it before several times, but have included the original photo showing the damage when it arrived here.
Different studio set ups I suspect, only the cab sides and front were repainted and the colour blended in along the length of the firebox.Curious if the difference in "reds" is down to camera settings or background tone, or did the model receive a full repaint?
Beautiful model.
He hasn't seen it yetGreat rescue job Mick. I can only imagine the heartbreak after the drop and the joy of seeing it whole again. You must have a very pleased customer.
Fantastic job Mick on one of the best looking steam locos ever built (in my eyes).
ATB
OzzyO.
Mmmm, I think Mr Ozzy has the right callObviously after Bulleid's Pacifics of course...
That's a Swindon education for youone of the best looking steam locos ever built
Yes what he said ☝️☝️That's a Swindon education for you
Here's something a little left field triggered by a discussion today on Facebook about motor & gearbox clearances.
I've been meaning to do this for a long time now and today finally pulled the proverbial digit out. I'm not sure how or when others fit their motor gearboxes or test for clearances; but I frequently find that one orientation that's perfect for the chassis suddenly needs moving when you add the body, ash pan, brake gear.....insert excuse here......
Even when fitted you shouldn't really be soldering and spattering hot flux around drilling or grinding with it fitted, consequently it ends up going in and out during different stages of the build. In the case of the King I had to leave final positioning until the footplate (and at least firebox shell) was completed before I could work out clearances and final position, resulting in some hacking here and there to get the best position.
The upshot of all this was some sort of crash test dummy motor gearbox, one that you could install and work around, check clearances, grind, solder, drill and check side play with ill effect.
The first test one came out just fine, in this case the Slaters SG38 unit, my 1:1 unit has the older slightly longer motor fitted with the flat sides. Slaters latest drawing on their site shows a shorter cylindrical motor, which is what this crash dummy represents.
In time I'll do all the most popular ones I use, building up a stock of units I can just throw in with little care if they get damaged during the build.
I tend to make my driven axle rigid, especially if it's the rear one, so my motor fixings are really simple, two transverse bars that simply stop rotation of the unit under load, hence the solid gear box on the dummy.
Sometimes the motor is designed to float so I make a hook/claw that grabs one of the gearbox tubular spacers. Thus Mk II will have a slightly hollow gearbox with those spacers in the right place so you can fabricate the mounts with the dummy in place.
They also allow you to test several different types/designs before splashing out and buying one.
