Double post but this one is not the layout, but sound, not HO either but it belongs here more than elsewhere.
Having successfully navigated uploading a sound pack and changing the horn type I felt quite pleased, however the sound is very 'digital/clipped', I'd like a bit more bleed/fade in and out if that's possible?
I'm also assuming that any changes made in the sound section are not uploaded with the normal (decoder) write parameter command and need a full sound upload again?
![Img_2244.jpeg Img_2244.jpeg](https://www.westernthunder.co.uk/data/attachments/218/218756-3cd7337f390f08db5e9f7fe133bad31e.jpg)
Secondly, headlights front and rear, is it possible to have the leading full beam and trailing dimmed and then swap automatically with direction of travel?
