John Duffy
I really do like the look of these wagons - using wood makes all the difference. As a swag - is it laser cut thin ply? Which source and thickness are you using? Also it's bleeding obvious to me now but I presume using the black styrene will make painting the ironwork easier.
Adrian for 4mm scale, the bodies are laser cut, 1mm Baltic Ply and for my 7mm work I use 1.5mm. The ironwork is a laser cut, 0.2mm material called Laserboard. Earlier on in the thread I was using 300 gms card, which worked well, but this material is just a bit easier to work with. I mark the bolt positions so that it is easier to locate the bolt heads. I can use them with the rivet press or as I have done in these last couple, to locate styrene slices. The plan is to make a set of standard parts that I can make myself some "kits" with.
I have now received some decals, so hopefully further progress will be made over the weekend or early next week. I'm also in the process of getting some sprung W Irons made that will include the curved retaining plate that the L&Y used on most of its vehicles.
Hopefully some updates to follow.
