Of course! Talk about not engaging brain before typing….
I also wanted to echo your “shout-out” to styrene_engineer on Instagram, some amazing creations going on there, not least the exhausts!
@Pencarrow is also amazing and has influenced my current building, of which, more soon.
Thanks again
Thank you John, very kind. Always nice to hear that people find my posts on worrying plasticard useful, it can sometimes feel like talking to an empty room. Cheers!
Lyndhurstman
Trayed Me
The LOWFIT - supposedly a ‘quickie’ - gets finished. It’s taken most of last week off and on to get this far. Modelling time has been few and far.
All the white bits are ‘artisanal’ (more the latter syllable, than the former ). As mentioned previously, the white blocks are from the previous builders ‘bespoke’ tension lock solution. I took them off the last one, but they were a bugger to shift (I think they had shares in Araldite) so I’d left them in. The brakes are from Stores. I need to finish cleaning up the flash… The tie rods are 1 mm brass angle, and the vac pipes from Lanarkshire. A lowdown shot highlighted the need to add the supports between floor and solebar..
It seems like a while since I’ve done a vac fitted wagon!
Jan
Lyndhurstman
A Transfer Of Appreciation
Just a little (typically over-worded :rolleyes: ) post to give due recognition - and associated grateful thanks - to Steve at Railtec. A custom request. Ordered on Monday (after measuring existing characters on a transfer sheet with verniers to ensure I’d got it right), delivered on Wednesday. Placement the same day…
Parked in a siding for 24 hours to allow it to harden off… wish me luck with the ‘11T’ branding; it’s even smaller!
Jan
Lyndhurstman
Out With A Bang
A102D60B-5EDF-4D52-A517-F4369E65C2D1.jpegThe BR 1/260 is done. Numbered after a photo in my collection. The GUNPOWDER was custom made for me by Steve at Railtec and the other numbers and letters - individually applied (I’m having a big glass of something in a minute, don’t you worry!) are from his range too.
I still need to waft it with some aerosol varnish, but that can wait until the transfers are set.
Come On You Greens! :D
Jan
Lyndhurstman
Hi Jon
Thanks. I actually like how this one turned out :)
Regarding the result (which I acknowledge was against a less-than-first-eleven :D) I do celebrate it; we've had a woeful run of managers, injuries, and form. So any underestimating (or arrogance/indifference/poor judgement) by Slot is gratefully received :D
Jan
