Highbridge and Dartmouth
Paul Townsend
Olton Bridge model was built by the late Mike Jolly.
He bequeathed it to a chum who custodied it for many years but in return for services rendered offered it to me around 2013.
The timing was just right so I adapted my model design for Dartmouth in Broad Gauge c. 1875 to include it.
The prototype was a Brunel design for OWW Rly to cross a road at Olton near Bromsgrove. In the end Directors got cold feet and used a wrought iron bridge instead. The location exists today, line was quadrupled later on and a newer boring bridge is now in place.
In my fantasy world, the directors of Totnes and Dqartmouth Rly bought the drawings and had it built just north of Dartmouth to provide for the South Hams Rly to go below and bridge a stream. It would have been the last timber structure built using IKB's design.
The baseboards with this bridge and my foreground mixed gauge trackwork was entered into Scalefour North "18.83 Challenge" in 2014 at Wakefield and won the Eileen's Emporium award for best scratch-build in the show. So that was partly for my track and partly in memorium to Mike Jolly.
Paul Townsend
I’d like some more words and pictures about that bridge, please. :thumbs:
Some wider angle pix in my post of Jan 24th and some more words here today.
I have been tidying up some wiring and stowing some Merg modules below the track bed this week.
I now have to plan the detail of the track that crosses a BBd joint at the same acute angle as the bridge...it will be a dropin small section.
john lewsey
It is booked to appear at RailWells in August 2024, NOT this year!
However , I will be at RailWells this August doing demo of Broad gauge modelling so stop for a chat.
Hi Paul I can't Im afraid as I live in España and at the moment my wife is having chemo so travelling by plane is Just a bit risky. (colds etc). Someone I know recently got on a plane even though she knew that she had Covid, I wasn't impressed.
Paul Townsend
I have been bothered by a bit of plain BG track causing derailments and hard to diagnose so I have built a BG version of the Masokits track deviation detector wagon. I have used a P4 vesion for years successfully at Highbridge. This new version gave instant diagnosis of a slight twist over just 2 sleepers....easily rectified and cured.Track deviation detector_Masokits_IMG_2536.jpg
Herb Garden
I have been bothered by a bit of plain BG track causing derailments and hard to diagnose so I have built a BG version of the Masokits track deviation detector wagon. I have used a P4 vesion for years successfully at Highbridge. This new version gave instant diagnosis of a slight twist over just 2 sleepers....easily rectified and cured.View attachment 189920
Paul,
That looks like a very neat bit of kit, could you explain further how it works and how you constructed it?
Paul Townsend
Masokits offer an etch (£10) for P4 or EM, with excellent instructions. It clearly lists the parts you need to buy to complete the job.
I used Ultrascale wheels to get the best concentricity otherwise wheel wobble confuses the issue. They are mounted on BG axles. I need to grind off the pinponints else picking it up can be painful ! I filed a wheel clearance arch at the end where the etch din't have one. Michael specifies the gauge of lead to use but as I ran out of lead sheet I made a little brass box from etch offcuts to be soldered on the top, filled it with liquid lead and sealed it with UHU and a brass lid. Mine weighs about 100 grams so stays firmly on the track! I added 2mm ID tube my long axles to control wheel sideplay.
It works by having one axle rocking on dodgy track, on the left in my piccie. This is connected to a vertical plate whose top edge activates the wire levers. The levers amplify the movement and shows it on the coloured scale with 4 grades of indication. Perfect track is shown by the indicator always hovring in the white. Red guarantees derailments. I was tired at painting time so hands were wobbly. Its functional and not cosmetic so I don't mind the splotchy painted patches.
Highly recommended if you have lots of track to build and maintain. It is very sensitive and I have learnt to trust the yellow and brown indicated grades on my old P4 version.
6 Wheel carriages
Paul Townsend
Dartmouth Broad Gauge has some lovely 6 wheel carriages built by a friend and on loan to me.
They have tended to derail in places where the track is OK but complex, eg curves on gradients or complex pointwork.
Most are built from Broad Gauge Society kits.
Investigation revealed that they all have sprung suspension with a single spring wire each side of .013" gauge. Weights are generally in the 60-90 Gram range which is correct for these vehicles.
The static spring deflection was negligible and needed at least 40 grams weight adding to sit correctly.
I am modifying them to individual springs per axlebox using .011" wire for the outers and .009" for the middle axle. This follows advice for CSB locos to avoid see-sawing on the middle axle. One required weight adding as it was < 50 grams.
I also am ensuring the B2B gauge is at the top end of the tolerance range.
Where these mods are done the reliability is much improved.
Paul Townsend
I had expected to give another update on progress chair gluing and track painting & ballasting but two MR factors have stolen July planned work. Also the rebuild of the kitchen has caused some management issues together with a visit from a Rat.
I had a self-inflicted fault in the electronics that corrupted the firmware in a few Merg kits.
It took a while to diagnose the cause and restore working firmware.
The electric design has always been primarily for DCC but as I now can run trial trains ( locos on loan are DC only )I am finding I need to add some more places where a loco can be isolated to allow for several "locos in steam".
Having got into the DCC way of wiring I had neglected that design requirement.
So I am installing some additional relays driven by CBUS to do the job...desirable but not much good for pictorial reporting ! Thats 70% done so back to sticking half chairs. When insanity approaches I will finish the added relays caper.
Highbridge
Paul Townsend
Moving on...sleepless in the tropical night.
Recent activity for Highbridge is to consolidate the success of the new led strip lighting by removing the previous installatikon of led spots and floods. The ceiling is now decluttered.
Anyone want some MR12 12volt led spots ? ( same fitting as old QI halogen 12v lamps)
I have a quantity of various wattages and beam angles now going spare at a low price. Not more than a few hundred hours use...rated life is many 1000s of hours.
email me if interested.
Paul Townsend
Highbridge has long had a cassette access point near the fiddle yard so excess or visiting stock can be stored off the layout.
When we moved house several years ago the upheaval disrupted the track alignment badly so the cassettes were unuseable.
Last evening Tim and I finally bit the bullet...soaked the naked bit of track with warm water to soften the PVA....prised up the sleepers and re stuck with some packing cardboard.
When dry I will revisit with the soldering iron to fine tune the bumps and hopefully bring the cassette system back into use.
The fiddle yard does get overcrowded.......
Dartmouth
Paul Townsend
At Dartmouth the recent progress has centred on my need to do something interesting in between sessions of sticking down half chairs in order to preserve sanity and keep the mojo well.
Decisions have been made and implementation has commenced in several vital areas:
Signalling
What to plant on the model for 1875? There will be a mix of double sided semaphores, disc and Xbars, bobby with a red flag etc.
All servo controlled and pluggable for travelling safety. Ground signals will be capstans. In BG era, bobby went out with a long pole to operate the capstan turning it through 90 degrees to operate a switch. On top was a flag so drivers could see how the turnout was set more clearly than peering at swicth blades.
Lever frame's relationship to the signal box at the station. Both were brand new concepts at the time and so the installations were primitive and "Beta versions". I have a lovely brass well engineered 21 lever frame to which I am adding microswitches so it will talk to CBUS. It already has a full mechanical locking frame for me to use in years to come.
Early design of Saxby and Farmer signal box needs building. It controlled the station.
Thanks to Becasse in another place for info and advice.
Couplers
90% certain to be Dinghams, trials commenced. Fallback is Alex Jacksons of which I have experience at Highbridge S&DJR
Uncouplers
may be servo lifted permanent magnets or electromagnets since Paul Segar just pointed me at a low current coil on Ebay.
Most such coils from our MR traders are too greedy for current in my book.
Whichever actuator I choose I will have several operated from one button since all the UCs in one JMRI block will operate together.
Clearly only one loco moves at a time within a block so any static waggons over a UC won't matter.
Simultaneous is literally true for electromagnets as they will be wired in parallel, hence desire for low current per coil.
If servos, which will be digital, the bunch will be sequenced at say 1/4 sec intervals ( by Merg drivers). This ensures total current is no more than for 1 servo.
6 wheel BG vehicles.
Altering the spring suspensions as mentioned a while ago.
Where was I for 3 years? New
Paul Townsend
Still here but clobbered by life events!
I have a constant dizziness problem when vertical and lost sight in one eye suddenly last July.
I am no longer able to enjoy operating Highbridge on my own, and can only do it when chums visit to do 3 link couplings, rerailing and routine maintenance.
Sitting at workbench is not compromised by dizziness, but loss of 3d depth perception is challenging so building models is much slower now.
For these health issues Progress on Dartmouth stopped last Autumn but is now resuming slowly. It is relatively easy to extract one baseboard at a time so I am reorganising workspace so I can plonk a 4ft board on it and work on that from a chair or stool. Painting of rails and ballasting can resume.
Due to recognition that my years are running away my time to build BG locos and stock seems inadequate so for these health issues first time in my 76 years of railway modelling I have exercised “check book modelling “.
I was able to buy several locos and rolling stock at a Broad Gauge Society auction yesterday. All came from the bequeathed estate of Dr Roger. White so BGS and some bidders are very happy. Roger was a founder member of BGS in 1980, a heart surgeon in Hartlepool who retired to Hereford. He had experience in standard gauge modelling in EM &P4
Those who knew him won’t be surprised to hear that the models auctioned are all built to a high standard and very well decorated .
Wearing my BGS Committee hat I was disappointed that most items were sold for less than one would pay for the parts today. However Bidders walked away with bargains.
All the locos I bought have problems below the footplate. In some cases EM wheels need replacing either P4 versions. All except one need the B2B opening to meet the standard for BG P4. Some need the suspension modernising.
On test track,running is poor and one is a non runner.
That loco was professionally built for Roger less than 8 years ago and has CSB, HighLevel gearbox and zMashima can.
Separating body and chassis revealed a broken wire joint. Thus 30mins with screwdriver and iron will see it restored to perfection.
Paul Townsend
So the 30 mins was optimistic.
All easy and chassi runs OK now.
Reassembling to body use 4 screws and awkward brake cross shafts get in the way of the screwdriver.
Best tweezers, head magnifier, good jewellers driver would have made it a 3min doddle a year ago.
3D vision lacking and tired from hard day yesterday. Try again after a cuppa or tomorrow.
I must resist the temptation to open up one of the other locos until first is reassembled!
I will add some pix of these lovely locos as I start work on each one. Here is 3504, the current repair to wire.
I have just noticed some damage to the front bufferbeam and LHS buffer is bent.
Sad but it looks like a very heavy shunt on a curve....quite realistic actually.
If I have to replace the buffer I will do both on front and try fitting sprung jobbies, however the original pro builder probably didn't due lack of space.
For non BG enthusiasts this was a Dean convertible of quite late in the BG era, so was made narrow gauge after 1892 and they continued working. "Proper" earlier GWR BG locos pre the need for convertibles, had no numbers, only names
paulhb
Lovely looking engines Paul
Paul
Paul Townsend
18:30 (52 minutes ago)
Paul
3504 is now running well after replacing one motor wire with a slightly longer piece
On reassembly the other motor wire broke away from the PCB but I resoldered it without disassembly.
There are 3 screws not 4. Thwe4th attaches the chimney ISTR, must have a look at the detructions !
I have straightened the buffer and beam but it needs more work when I decide how. I may put a closeup pic here to get advice.
This loco will get trials now on Dartmouth asap.
However something has happened to the electrics on the layout which will need to get attention first.
My next loco to examine is this 4-2-4WT by Pearson for Bristol & Exeter Rly.
I will start a new thread for that.
B&E 9ft Single New
Paul Townsend
This is the second of my locos bought at BGS auction last Saturday.
The 4-2-4WT was a Pearson design, recognised as a classic 9ft single for B&E. 8 were built 1853-1873 by Rothwell & Co.
The model was scratchbuilt by Kay Butler for Dr Roger White who died in late 2024 and bequeathed his models to Broad Gauge Society.
Wearing my 4mm Trade Officer hat I was tasked with assessing 15 locos for quality and condition so bidders has some knowledge.
Roger had some curious ideas about B2B which is so critical for good running.
The wheels are EM but set to a B2B which is just under the P4 spec but too wide for EM. Very odd.
Unsurprisingly it ran OK on plain track but sometimes derails on my BG-P4 test track turnout.
The 9ft driver is flangeless and the actual drive is to one axle of each "bogie"
Here some pix, taken as received.
I now have to open it up to think about either widening B2B or wheel change to P4
Herb Garden
View attachment 261736View attachment 261737
What an incredible and interesting model. Both in the aesthetic qualities and it's mechanical nature. Looking forward to seeing more of it
