I have made reference to the Wirral OGG layout in the recent past and having been prompted by a certain gentleman from the West Midlands who is having an extension built - slowly and not in his favourite colour either! I remembered to take the camera to the Club last night, so................
It is 38' x 14'6" and the minimum radius is 5'9". When it was designed, we were housed in a primary school and it was decided that it would be a test track roundy-roundy constructed around Styrofoam boards to keep it lightweight and baseboard connections - both physical and electrical would be as simple as possible. That was April last year and generally speaking, those requirements have been met. Each of the outer 'Main' lines has a passing loop on both 'straights' so you can get three eight coach trains on each line. There are no connections between the two outer tracks but there are three sets of crossovers on the DCC 'Branch' as it is now called. The electrics are all done, points are 'hand driven' and the two outer tracks are DC controlled by Helmsman 5amp units fitted with volt and ammeters and hand held controllers. the two inner are DCC (we are awaiting the delivery of a Digitrax 8amp set-up).
Scenery was not on the original agenda, but my wife made a comment that perhaps a station could be 'clipped/hung' on the front straight to give more interest, so that is what is now being planned, to give two central through lines, two main line platforms, the inner one being an island to also serve the 'down' branch and finally, the 'up' branch. The NE Cheshire layout at Telford last weekend also had a similar idea.
