7mm Finney7 5972 Olton Hall ( aka )
P A D
Hi Mick,
Very nice indeed. I used those mud hole covers from Malcolm Mitchell somd time ago (I think on my Scorpio large prairie), but then forgot about them until somebody mentioned them on here. I used them on the 3P but even fixing with epoxy as suggested I got one in the wrong position. I was prepared to trash it getting it off to replace with another, but just putting a sharp blade under the rear edge and applying a little force caused ig to ping off with no damage. It left a perfectly resin cast mud hole in place that was then scraped off. I don't know if that would work every time, but sometimes you get lucky.
Peter
7mmMick
Cheers Peter,
The instructions that come with them suggest epoxy for securing but I soldered mine as I knew fine adjustment maybe needed and I’m just not confident enough to get the positioning absolutely bang on. Especially with the small strip to represent the hinge.
@SimonT Sounds interesting, why not :thumbs::D
Mick
