A simple out of the box build whilst waiting for etch work for the W1.
This should help with the 1:32 build in so much as any areas that need tweaking will be found on the 7mm quite quickly and save time and photo tools for the larger version.
Prototype engine is a late BR wide cab with 4500 gallon narrow tender.
Everything just fits where it should so far, it takes longer to clean all the cusps off and photograph than it does to actually build it.
The one thing that is beginning to tick me off, and is not a reflection on this or any other kit, is what I call flux mold.
No matter how little I put on, scrub and wash afterward, this mold starts to grow, it starts off as small orange spots just hours after washing and if left just green and begins to fur up in a few days. I use the safety flux from Building O Gauge Online, mind it's decanted into a jar and it's pretty low now and been in use for a couple of years I'd guess. I suppose I should decant some more and see if the problem persists.
It's clearly flux spatter when it's getting hot and spitting and is usually no where near where your working, and usually inside the frames where it's a witch to clean anyway.
I usually wash in warm water and fairy liquid after each major soldering session, on average every couple of hours, and occasionally a quick squirt with Cillit Bang but only for 10-15 seconds or so as it leaches the 'zinc'? and even nickle silver turns orange.
You can just see the orange spots here on the inside of the frame near the wheel arch etch fixings, it's been a couple of hours since it's last wash.
Having said all this, when I did the W1 cab roof last week none of this ever appeared, same flux and 145°C solder but iron at 300°C, mind that was easy to burnish with a soft fibre brush.
The frame stays were done at 400°C with 188°C solder but I think this spatter has come from the small brass part under the cylinders which is soldered at 300°C with 145°C solder.
What I'd like is something that'll neutralise this issue and I'm wondering if a sonic bath will help, I'm at the stage now where my work is just not clean enough any more.
Anyway, more photos as work progresses.
Mick D
Mick D
