timbowales
Nigel, does that bogie pivot both horizontally and vertically?
Do you insulate the inside of the sideframes to avoid shorts?
Hi Tim,Nigel, does that bogie pivot both horizontally and vertically?
Hi Simon,Pondering said bogie. It’s a better way of entertaining myself over breakfast than reading the ever more depressing news.
I can see that it can allow some equalisation, assuming it can roll (around the longitudinal axis) as well as pitch (transverse axis), but my pondering suggests that it’s yaw (vertical axis) is of limited benefit, as it only shortens the fixed wheelbase by roughly one quarter. The limiting angle between the vehicle axis and the track centreline at the rear (fixed) axle is directly related to that fixed wheelbase chord and the curve radius, and for that to matter, the radius would have to be rather tight, I guess.
or am I missing something?
So when Mrs B got her way and our kitchen was extended I did invest in a Quooker tap. If I’m feeling brave I might try it out on the tablet catcher and see if it shifts…. Thanks for the tip Simon.Might a fine stream of near-boiling water be sufficient to unsolder the catcher without demolishing the entire thing into its constituent parts?
Hi Dave,I presume there won't be so many trips to North Wales for a few months, or do you get involved in winter maintenance?
Congratulations on safely rearranging the tablet catchers without turning them into a shapeless blob. By-the-way, the item you had to replicate in plastic card was an external water filter box - nothing to do with grease.
Good luck with the loco. As you say, a kit of its time.
Dave.
The packs come with magnetic additional ends to replicate the rubber infills so I think the idea is the ends you can see (although I don’t know why it has also been applied to the brake ends) can be removed and replaced by others. I’m just going to get two boxes out and see how it works…Is there any obvious reason, why the Coronation Coaches appear to have very badly fiitting Corridor Ends, the Roof and Side joins are simply awful ??
Again the piece covering the centre gap between the Coaches is flexible/removable and again much lower than the Roof ?.
