Interesting!
I was thinking to buy the TBM220, but I decided the top speed is too low for small drills below 2mm.
Brass alloys for casting require a cutting speed of 220-240m/min with carbide drills and 70-80m/min with HSS bits. For a 2mm diameter, this is already 35000rpm for carbide and 11000 rpm for HSS. For a 1mm diameter, it would be 70000 / 22000 rpm.
So I made up my mind to combine a Proxxon IBS/E with a drill stand MB200. The IBS/E goes up to 22000 rpm and can also be used handheld. It has a decent torque. I NEVER touched the tilting mechanism, so the holes are perpendicular to the table. For carbide drills, a massive vice is mandatory. Any movement of the part to be drilled will brake the drill bit immediately.
I use common 1/8" drill bits that are widely used in PCB production. They are easily available from 0.3mm upwards. The standard collet holds them perfectly. Don't buy the cheap chinese carbide drills. They are all blunt.
Michael
