Hi
A bit on the body today. I was demonstrating at the Wolverhampton show over the weekend, and took Lady G along to work on the cab. I managed to get a reasonable amount done. The Gladiator kit has 2 huge 'boxes' either side of the backhead, which means truly massive cut-outs in the backhead to accommodate them. Unfortunately I didn't take any before pics, but it is awful. So, to minimise the cut outs in the backhead, I needed to make proper splashers and smaller boxes.
It's all trial and error as I am working with the holes I have, and I'm trying to avoid damage to the exterior paintwork while cleaning loads of superglue off the cab interior. Not really much fun that, but get it cleaned up I did, and the splashers and boxes fabricated, thus able to demonstrate the use of a piercing saw, how to replace blades
, use of a guillotine, blowtorching pieces apart, and the requirement for asbestos fingers, as well as soldering in a confined space
And while I had the model out, a couple of pics of the current state of play. I have repainted the cab sides and renumbered it for Lady G, and started to clean up the splasher and boiler where the previous plate was - more gobs of superglue
. Fortunately, the superglue was well attached to the green, so on the boiler, I was able to get it down to primer. The splasher tops should be black anyway so no great issue there.
On thing I am stuck on is the shape and size of the bracket on the drivers side for the reversing handle (the mechanism is on the outside of the cab). Anyone have any ideas? [Edit - sloppy wording. It's the size and shape of the reversing casing I'm after. The cover is on the outside of the cab]
