Focalplane
Very nice work, Rob!
Thanks Dave,Rob.
Well recovered - no one would ever know. Must have been a heart sinking moment when you realised your mistake.
Dave.
Thanks Len,Hi Rob, I love the build you are doing to this kit. Have you come across any problems with the boiler, as when Nick Dunhill did 3 a couple of years ago he had problems with making it square?
Len
SimondRob
I think there is a perennial problem here.
If you rivet it before you roll it, the pinch roller will undo your hard work.
If you roll it before you rivet it, how do you rivet it?
I could imagine making a rivet press that would work on a tube, I guess.
other ideas?
Hi Rob, looks like a 2nd test with another piece of brass sheet after you've pressed a row of rivets out. Using a piece of 1mm thick card to protect the rivets it should be okay. I'm unsure if the 'pinching' is likely to damage the rivets or the rollers. Good luck!Today has been very productive in terms of tackling the smokebox.
After a conversation about rolling a 0.45mm sheet including rivets pressed out with Richard Spoors @Richard Spoors. Where we concluded that my GW 10” rollers were not man enough for the job and would flex. I decided to have a go at rolling the smokebox using the rolling bars on my Warco ‘MiniFormit’ which are a touch over 28mm in diameter so unlikely to flex.
Although I have had it for a number of years, I have only ever used it as a guillotine until today. Rather than risk the actual smokebox to an unknown piece of equipment I decided that I would cut a similar sized piece of 0.45mm sheet and have a go.
Although the actual process of rolling is broadly similar to the GW roller the Warco rollers are of the pinch variety and I must have pinched a little unevenly because I noted on my test piece that one end was marginally wider than the other. Not enough to be an issue but something to be aware of.
The other issue that I encountered was controlling the amount of ‘roll’ On the GW rollers there are two cap head screws on the top that you tighten down simultaneously to get an even roll. The adjustment screws are on the back of the Warco unit so harder to see. They consist of a threaded rod with a round knob locked on with a nut.
Those issues aside, the first go turned out pretty good and it’s perfectly usable. If I don’t find a use for it on a loco at some point, I can always use it as a wagon load.
Having done the rolling, I had some thoughts about how best to regulate the amount of roll as the screws are adjusted and came up with the idea of adding a blob of paint on the flats of the locking nut.
I wound both of them to a fixed point and then put a blob of coloured paint on the opposite flats on both nuts – White, Red and Blue so I can now see that I have turned them both by equal amounts.
Not the easiest thing to photograph as it's bolted to the bench and the screws are on the back.
It certainly works for me Simon although I do like Ian's rubber/neoprene idea too. I usually keep a piece of card in my GW roller box but noted yesterday that it was getting a bit tired so I need to replace it. - good excuse to eat more biscuits...So, the answer is “wrap it in card”.
